Add a PTO pump
   / Add a PTO pump #11
Trying to wrap my head around 25 GPM making a splitter cyl with a 12 GPM(?) valve cycle much faster, unless I missed something.
Subscribed to see where this goes.
   / Add a PTO pump #12
I would think adding large capacity PTO pump it would need to have its own closes loop system with large reservoir and control valves/cylinders .... Probably not going to be at all effective piggybacked on system you already seem to think that is to small.....
   / Add a PTO pump #13
Next door has a pull-behind man lift for the orchard. I got a brief look at it when his son was putting up Christmas lights a while back. PTO pump pro'ly OC & IIRC has a reservoir on the chassis a bit smaller than a 10 gal fish tank. Maybe 8 & holds 5? Don't recall seeing a fan or shroud on it, but it's not cycled/worked like with a splitter or chipper & I'd bet it runs at 1500 psi or so vs >2500.
I wonder if a beer-can car radiator might be used as an oil cooler on a fat high volume return line, say vs adapting a car/truck oil/trans cooler with thinner lines & less flow.
   / Add a PTO pump #14
10' Fork Extensions (A53316)
10' Fork...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A55787)
2021 ASV RT-135...
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2020 Chevrolet Silverado Pickup Truck (A55852)
2020 Chevrolet...
1998 John Deere 7610 (A53314)
1998 John Deere...
2017 Nissan NV200 Cargo Van (A53422)
2017 Nissan NV200...
