Add a zerk?? How to...
   / Add a zerk?? How to... #11
It looks like 8 is pressed into 9. If so, drill and tap a hole through 8 and 9 and install the zerc into 9. It will push grease into the gap between 8 and the shaft until grease spews out the topor bottom. I would assume that the shaft moves around enough to distribute the grease. The zerc is a tapered thread so tap it shallow so you don't end up with zerc in the shaft.
Thanks Rob, that looks like a good process. I'm going to try a couple shots of silicone before I mow next time, and if it doesn't get better then I will install the grease fittings.
   / Add a zerk?? How to... #13
Highbeam is right if 8 and 9 are press-fit together, basically what I suggested. However, even if press fit, it would be wise to run a groove around 8 anyway in case...for some reason it rotates and shuts off the hole in 9 (Murphy's Law). I'm a firm believer in Murphy's law, in fact I think he was an Optimist.
On the zerks...Napa has a whole selection of them...straight, 90° and 45° bends...etc. Also you can get them with 1/4"-28 threads or tapered 1/8" NPT or even Metric threads. Use whatever you have to tap with. I like using the 1/8" NPT tapered for exactly the reason Highbeam pointed out.
   / Add a zerk?? How to... #14
Rob:
You'll never make a good farmer. Good farmers NEVER grease anything. Good farmers DON'T own a grease gun either. Good farmers just run a part dry and sell the implement at an auction to an unsuspecting buyer, usually... ME . /forums/images/graemlins/grin.gif
2015 FORD F-250 SUPER DUTY (A52472)
2015 FORD F-250...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
1264 (A50490)
1264 (A50490)
