crashz
Veteran Member
From what I know of diesel injections systems: The new high pressure injection systems are a completley different animal for the past fuel systems, as injection pumps (positive displacement, but not pluger style!) that rely on the fuel to cool the pump more than lubricate it. Old systems use a plunger type of pump (inline or rotary) that are completely dependant on the fuel as a lubricant for very close tolerance, moving parts under strain. The plunger or piston requires lubrication in the bore, and some are cam driven, therefore the cam face requires lubrication. At reasonably high injection pressures (say 1000 psi), this puts a lot of strain on those hard parts.
Introduce any particulate matter into the system, and either one will wear significantly and loose the close tolerances, increasing slip, and decreasing availible output pressure.
Therefore any diesel fuel system would benefit from additional filtration and water separation, but the older piston/plunger style pumps will see much more benfits in addtional lubrication. Not to say the high pressure systems won't, as the lift pumps may last longer and the fuel viscosity would be increased slightly, but there is less of an actual wear issue there.
