etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,035
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
When I got my Yanmar YM2310 the shifter mechanism was rusted stiff. After months of penetrating oil and working the lever I finally got it free a couple days ago. I decided, after cleaning all the rust off, that it needed some way to be lubricated. The shifter forks are made of 5mm thick steel with bushings welded to them. The bushings pass through the steel. The only good place to add the zerks was on the edge of the steel but the steel was too thin for that. So I made a couple 3/8 diameter x 3/8 long steel adapters that I drilled through with a 3/32 drill and then drilled and tapped 1/4-28 for the zerks. I welded these to the edge of the steel and then used the 3/32 hole already drilled as a drill guide to drill through the steel and through the bushings. Now, after it is all assembled, I greased the works through the new zerks. Since the shifter mechanism gets wet from the weather this solution will keep the forks from ever rusting on the shaft again.
Eric
Eric
