Adding a cylinder mount to rear blade
   / Adding a cylinder mount to rear blade
There isn't really much doubt that I have supply relief only, not on the work ports. My only option is to tee in a relief valve on both work hoses, with a third line to dump any relieved oil back to the sump. In all honesty, that probably isn't going to happen until I have time and money on my hands, which isn't likely anytime in the near future.
So, until then it's a calculated risk. It has to be used with common sense, which I agree is not as common as the term implies.
A few modifications since the original install, the old cylinder got bent from overextension. The mount had to be re-engineered/replaced, the thread detailing the process is here.
http://www.tractorbynet.com/forums/hydraulics/192127-cylinder-travel-limiter.html
LD1, while I was replacing the cylinder, I went with a 3 inch bore and the distance from the pivot to the cylinder mount is 10 inches. With no relief in the work ports, to develop 3000 psi in the cylinder would require nearly 6000 pounds of force on the blade tip, at least on the large diameter of the piston. Less on the small diameter, 4400 lbs, since the new cylinder has a 1.5 inch rod instead of 1.25 on the old one.
With the safety factor built into hoses and cylinders etc, this should be relatively safe, I suspect the blade will bend before I get to either of those points.
Sean
   / Adding a cylinder mount to rear blade #23
Sean
I dont Hate saying I told you so. So I wont:D But I think you current choice of cylinder is going to work out MUCH better for you.
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A56859)
2014 Glasstream...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
Heavy Duty 44in Excavator Rake (Fits CAT 305) (New/Unused) (A59225)
Heavy Duty 44in...
2015 Caterpillar TL642C (A57148)
2015 Caterpillar...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
