Adding Hydraulic Fluid - 2007 Montana 5740C
   / Adding Hydraulic Fluid - 2007 Montana 5740C #1
SteveMo
New Brunswick, Canada
2006 Montana 5740C
Hi, All:
I just removed a blown hydraulic hose and should add back what was removed from the hose, so, I am asking:
1) What type of fluid to use (is it 80W90)?
2) Where to add the fluid? Is it one of the top bolts on top of the transfer case? I see a dipstick there but no idea what that reservoir is? Does the drivetrain share the same fluid?
Sorry for the newbie questions. The only manual I could find in the past for this tractor is in Chinese!
Thanks!
   / Adding Hydraulic Fluid - 2007 Montana 5740C #2
Hi, All:
Thanks!
You want tractor combination transmission/hydraulic fluid. Get it at any farm or tractor store.
Auto stores don't have it.
Do NOT use 80/90, power steering fluid, straight hydraulic fluid,or engine motor oil. Tractor combo hyd/transmission fluid is about 20wt and is special....and costs more.
There has to be a fill point somewhere close to that dipstick, or use a funnel and pour it in there.
luck,
rScotty
2021 Ram 1500 Classic Crew Cab Pickup Truck (A44572)
2021 Ram 1500...
2007 MACK CHN613 (A45333)
2007 MACK CHN613...
2011 C.GALLEGOS 130BBL VACUUM TRAILER (A47001)
2011 C.GALLEGOS...
2020 INTERNATIONAL MV607 (A45046)
2020 INTERNATIONAL...
2025 AllMetal K0720 UNUSED 20 ft. Bi-Parting Metal (A47484)
2025 AllMetal...
2025 KJ K0720 UNUSED 20 ft. Bi-Parting Metal Gates (A47484)
2025 KJ K0720...
