Adding weight to discs: Look what I did (photos)
   / Adding weight to discs: Look what I did (photos) #11
Are you happy with the weight or do you need more?
If you need more weight, build 2 more the same way and set them standing up. This will decrease crack possibilities, which are minimal anyway with the four bars.
I spoke with you when you planned the project. I misunderstood a little since I thought you were going to cast twice as thick as they are. (square cross section as opposed to rectangle) That's why I suggested the four bars.
Looks good.
   / Adding weight to discs: Look what I did (photos) #12
Hey thats an interesting setup. i also would like to know how well they hold up to rough discing.
I used railroad irons and cut holes in it and the disc and bolted it on.
I think you will be impressed on how well the extra weight makes them perform.
   / Adding weight to discs: Look what I did (photos) #13
They will continue to strengthen for some time. I bet they don't break! Nice job!
   / Adding weight to discs: Look what I did (photos) #14
Good job, but I'd park your disc indoors...
Those straps are made out of a material that is more than likely sensitive to UV rays of the sun to some degree... over time they will deteriorate... your acreage may vary.
Now all you need is a drag log...
Mike
The TC40DA handles the discs like they're paperweights. The only thing I notice is that I have to use 4WD in soft earth, and can't run in second gear. The weight is noticeable but not a problem. I do plow with a two bottom plow (I assume you meant dirt, not snow plowing?). Now, do I KNOW how to plow is an entirely different subject.
On another subject Mike, I'm indebted to you for your toolbox design. I built one using your plans and it's AWESOME. What a space and time saver!
Neilly2
I'm happy with the weight. The reason I went with the shape I did was to spread the load evenly, make securing the blocks easier, and most of all, to allow me to continue to easily adjust the discs . Thanks for your help.
Dixiedrifter:
The straps are temporary, I need to find something more durable. It's all I had on hand. Unfortunately I don't have an indoor area for my implements. I can only dream...
   / Adding weight to discs: Look what I did (photos) #18
Looks great.. how much did the disk set cost?
I'm digging up one of my old posts. Sorry. But in response to the last post the discs cost $1,000. They were "new" but weathered from sitting in the New Holland dealers for a year outdoors. Great investment. Heavy and very, very tough.
2018 WACKER NEUSON RTSC3 ROLLER (A52576)
2018 WACKER NEUSON...
MASSAGE CHAIR (A53843)
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
