Additional Hydraulics on a JD 455
   / Additional Hydraulics on a JD 455 #1
trrjohn
SE WI
John Deere -420's & 455's
I am looking for help in adding one or two additional hydraulic circuits on my JD 455. It has 2 included circuits which are used for the FEL near the center of the left side , which is 2 sets of quick connect ports, one of which is also used for the rear three point and center lift. The 3 point port is locked out when using the FEL by a 1/4 turn valve.
I would like to add a grapple to the FEL bucket and perhaps a hydraulic 3 pt center link for the box blade. I have included a PDF of the hydraulic schematic. It would also be nice to use the 3 point with the loader.
It appears that the power steering has a Power Beyond which currently feed the 2 spool control valve for the other functions. I guess I could hook a new valve with PB on that line and hook the PB from the new valve to the existing valve. And then hook all of the returns together.
Do I install a new valve (joy stick 2 spool) on the loader and re-pipe the loader line to the new valve using hoses and quick couplers OR ? ? ?.
I need ideas and HELP.
Thanks,
John
  • 425_455 hydraulic schematic.pdf
   / Additional Hydraulics on a JD 455 #2
It looks like the PB port from the steering valve may be the best place to add a valve into. The other option would be a diverter valve to operate you grapple.
I have attached 2 simplified PDF's of a before and after. It requires mounting a new loader valve on the removeable loader and using three sets of 1/4" quick couplers when you remove the loader. The new loader valve would be joystick with a PB port.
When you remove the loader, you recouple the power steering PB port to the original implemnet valve supply line to the exact same design as before modification, but with hoses instead of a steel tube..
Will this work??
John
  • Before Modification.pdf
  • AFter Valve Addition.pdf
   / Additional Hydraulics on a JD 455 #4
Will this work??
John
Yes John, that will work great. I like your drawings-I am jealous:D
JD 455 GPM is around 4.5.
Can I use 1/4" quick couplers on the 1/4" hoses or should I be using 3/8" quick connects??
Thanks,
John
   / Additional Hydraulics on a JD 455 #6
1/4" is fine for the QD's as well as the hoses.
After reviewing the specs onvarious quick disconnects, I have decided to use 3/8" connectors with a 7-9 GPM flow and 3/8" dia hoses. That should give "less restricted" flow and less heating.
J
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
2015 AMERITRAIL MANIFOLD TRAILER (A58214)
2015 AMERITRAIL...
TANK MANIFOLD (A55745)
CATERPILLAR 305 CR EXCAVATOR (A52709)
CATERPILLAR 305 CR...
