Oil & Fuel Additivies to the oil
   / Additivies to the oil #11
My 55 years of engine experience has shown that if you clean a gunked up , worn out engine, the excessive bearing and ring clearances start showing up and do what they do. The gunk just fills in the excessive clearances, same as a lot of the heavy/thick oil additives.
   / Additivies to the oil #12
So sludge was the only thing keeping it from knocking and rattling.
more than likely but it probably would have done another 200k as alot of those engines were reknowned for doing about 500k easily.
   / Additivies to the oil #13
THE SLUDGE REPORT
Im sorry to hear that it didn't work for you, I have washed many engines since then, and have never had a problem yet.
I think the trick is to just let the engine run at an idle, DO NOT rev them up during the wash process, that's what I was told to do, and just for 10 minutes.
yeah i ran it at idle for 10 or so minutes as they suggest....DO NOT REV OR LOAD ENGINE WHILE CLEANER IN USE. if it did that after 10 min idling i would hate to see what it did with a quick burn around the block!!
   / Additivies to the oil #14
correct. removing the only thing keeping the clearances realistic so it dont rattle or leak. having only 300k on it i was not worried about it doing that but now am very cautious, run oil for few hrs and change...repeat a few times including filter change and leave at that.
2019 MITSUBISHI OUTLANDER SPORT (A52472)
2019 MITSUBISHI...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A52577)
2016 INTERNATIONAL...
44510 (A51692)
44510 (A51692)
2011 Toyota RAV4 4x4 SUV (A51694)
2011 Toyota RAV4...
