3-Point Hitch adjustable lift arms
   / adjustable lift arms #1
jpm1
Platinum Member
Panther Lake, Oswego County New York
Mahindra 2810 HST, Kioti DK35SE HST
Does anyone know if there is a set of adjustable 3pt hitch lift arms for dor a mahindra 2810HST? Im looking for the kind that has a slide at the ball end. thanks 1ohn
From what i gather the proper name is "telescopic lower link ends"
   / adjustable lift arms #2
I wanted the same thing for my 3215. The best that I could come up with was John Deere. You can get a kit from them for a couple hundred and change. Everyone else wants you to buy the whole arm and those where 4-$600. John Deere had the best deal on them. The extendable lower links are a separate option for some of their tractors, so you don't have to buy the arm to get the links. :thumbsup: Have you thought about just using a quick hitch? That's what I'm going to do, but have to modify some of my implements to be able to use it. :(
I've done the "quick hitch" thing and its not 100 percent for me. Been in contact with Pat's and i believe i'm going that way and solve all the upcoming problems. Thanks for the info though .. . John
   / adjustable lift arms #4
I've been working on finding a way to convert it to extendable links, but haven't as yet found a resonably inexpensive way to do it.
   / adjustable lift arms #5
May I ask what you are considering a reasonable cost?
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
1973 TANDEM AXLE DUMP TRUCK (A52576)
1973 TANDEM AXLE...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
3-Point Hitch Root Grubber - Heavy-Duty Tree and Stump Puller for Tractors (A52748)
3-Point Hitch Root...
