The chains will not hold your box blade like rear stabilizers do.They attach from the tractor to your box pins they are on all larger tractors , your tractor has enough hp to bend the arms the stablizers will sove your problem. thanks
05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
I have busted the welded pins out of the clevis attachment on the lower adjustable stabilizer links. The ones that slide and have a pin that you use to lock them in position. Same deal with a pin pushed through a hole and then welded somewhat. I welded it once and then it broke again. The next time I took it to the bench and ground a nice bevel and put a lot of welding heat to the connection from both sides and now the weld is holding.
