Adjusting unloading on 2-Stage log splitter Pump
   / Adjusting unloading on 2-Stage log splitter Pump #11
so the relief on the valve needs adjusting nothing on the pump
   / Adjusting unloading on 2-Stage log splitter Pump #12
If one valve feeds the other, what do you mean about splitting the lines. All valves should be in series in an open center system.
You should be using a PB valve to feed the second valve.
Each valve will have it's own relief
   / Adjusting unloading on 2-Stage log splitter Pump #13
the line coming out of the pump I put a t in to run one to each valve and a t on the return to run the returns off each valve into one before going into the filter I will try to post some pics so you can see how I done it
   / Adjusting unloading on 2-Stage log splitter Pump #14
I don't believe open center valves will work in parrallel.
The fluid will find the circuit of least resistance.
The valves should be in series.
2017 Ford Explorer (A56859)
2017 Ford Explorer...
12 ft Shipping Container (A55973)
12 ft Shipping...
2007 DELTA GOOSENECK TRAILER (A58214)
2007 DELTA...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A56857)
2007 Godwin Pumps...
