Adjusting wheels
   / Adjusting wheels #1
ChrisC
Thanks all for the help I've received. I've stayed with the turf tires on my Kubota B2910 for the time being. I bought a set of chains from the local dealer, but there isn't enough clearance between the tires and the fender.
The dealer suggested I adjust the wheels. There's a spacer in between the wheel that needs to be flipped around.
I haven't done this before. Anything I need to know. I plan to borrow a jack from the neighbor.
I've worked on cars, so will follow the usual safety procedures: park in a level place, set the brake, block the wheels, etc.
Anything else I need to know?
Chris
   / Adjusting wheels #2
Hi Chris,
I'm not sure about your Kubota, but on my Ford the turf tires are adjusted by just turning them around. Gives a little extra room for chains, but unfortunately the valve stem ends up on the inside (not a huge problem). Hope this helps.
Dave
2002 Ford F-650 Crew Cab Dump Truck (A48081)
2002 Ford F-650...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
2013 Cadillac ATS Sedan (A50324)
2013 Cadillac ATS...
