Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
xlr82v2 said:I don't know how one could support that statement... I'd think that in all actuality, a transmission-driven PTO with an Overrunning clutch or even a Live PTO may be a bit safer to operate (if you can even quantify that) than an Independent PTO in the event of a breakdown or whatnot... since when you step on the clutch, EVERYTHING stops. Independent PTO must be disengaged with the lever, which isn't quite as "automatic" as stepping on the clutch when the machine behind you starts trying to beat itself or whatever got underneath it to death.
I see 2 issues with that though.. When you stomp a clutch.. you just disengage the engine power.. if the mower is spinning wildly... it will still spin wildly with your foot slammed down on the clutch.
Many independent pto also have a pto brake... ie.. when you turn of fthe pto.. it is quickly slowed to a stop.
There are ways to mitigate this.. dumping a throttle will dump pto speed... this will help with either setup.
soundguy
