Advice from tractor gurus
   / Advice from tractor gurus #11
"I would consider other brands of new tractors that will give you more hp per dollar (Mahindra, Branson, Montana, TYM, Kama, Koiti) or shop around for a 4-5 year old used tractor in the 35-45 hp range."
Only if you have a dealer nearby!
You'd be better off with a used big brand mchine for parts/service.
   / Advice from tractor gurus #12
Go with the Case, find a 6-7' bush hog to go with it, and get to cutting! It won't take you long to be happy about the horses under the hood... Finish mowing around the house can be done with a RFM, or a cheaper box store machine.
I have a 2305, and it is definetly too small for your acreage. I think the 2320 is the small side of acceptable for your plans. Personally, I'd want nothing smaller than a 2520 (or similar orange/blue machines). However, given your price range, stay with the Case...
   / Advice from tractor gurus #13
Howdy, welcome.
18 ac.. I can sure tell you that a 33 hp tractor probably won't be too much tractor for that size of land.
I get around with a 95hp tractor on less land than that.. and have a 72hp one to help it out.. plus quite a few inthe 13-50hp range as other helpers and toys.. ( I have a problem/.. you don't need that many.. )..
look at it like this.. 10ac takes about 5-6hrs to mow with a 5' mower.. your 33hp machine is gonna probably mow with a 5' rough mower.. or if the grass is light without much brush maybee a 6' mower
Decide how often you want to mow, and how llong you want to take.. then start there as a hp need.. then look at tractors in that range. Plan for other future tasks.. but plan the tractor purchase to do 80% of the work.. IE.. if you have 1-2 tasks that need a monster tractor, andthe rest are medium jobs... buy the medium job tractor and hire out the 1-2 huge jobs.
Soundguy
bigsky355 said:
Hi guys,
My name is Chris. I have been doing some research on this forum over the last month or so- VERY informative site. I need some advice at this point on selecting the right tractor given my situation.
I have about 18 acres in Montana with wild grass, sage, cactus, some rock etc. that I will need to keep short (fires out here have been crazy- another one started up last night outside of town). Will be using a bush hog type set up for that. I have a gravel road that will need grading now and then as well. Looking for a loader for misc landscaping jobs.
Three dealerships in town- JD, Kubota, NH/Case
My budget will have to be less than 20, ideally around 16 if possible. I am leaning toward something smaller rather than something bigger. The biggest job will be the mowing so I should not be putting the tractor through too much stress (very much just a weekend warrior)
Models I have been considering JD 2320 (2305 was recommended by the dealership as a possibility as well but I think this may be a bit too low/ small for my needs. Also interested in equivalent Kubota models (7610?).
Have a buddy who is a tractor mechanic and he is VERY biased toward NH/Case. He knows of a DX33 for 16900 with loader, low miles, manual tran. I think this may be too big for my needs. Also I think I would like to have hydrostat, mid pto which this one does not have.
Apologize for the long winded initial post but wanted to give you all as much info as possible up front. I am very much a city boy now living in the country and loving every minute of it.
Thanks in advance,
Chris
Again appreciate the comments guys. I drove both the Case 33 today (30 hours on the clock) and a 2520 (the JD dealership didn't have a 2320 on the lot). Very different feel to both of them. Gear drive not as smooth as the HST but the Case was definitely much more tractor for the money. I guess an option as previously posted would be to hire out someone to cut the acreage and use a smaller tractor for jobs closer to the house (what fun is that). I guess I am still trying to get my head around the up front costs on these beasts.
   / Advice from tractor gurus #15
bigsky,
I really think, based on your comments, you are looking at tractors that are too small. Forgive me for not knowing the details of the Case machine, but I think that is the SMALLEST machine you could reasonably choose. With wide open spaces you want the most horsepower and size you can afford. I am not a big fan of pure gear-drive machines, but I would look at a JD 790 or 990 when you are looking also. I am surprised that Roy did not mention this as he sleeps with his 790--the true love of his life (kidding, Roy). He has gotten great service from this machine and it NEW is in the ballpark of your used Case machine. It these days is not hard to find a used tractor, but it is hard to find a GOOD used tractor, so be careful. You do not want to inherit problems, and they might not always be immediately noted. If you do not mind shifting gears the two machines noted from the JD line should be considered. They would be a "bit more tractor" than the 2520 for the tasks mentioned and definitely more than the 2320. I do not wish to steer you JD, but I am not really familiar with some offerings from other companies, where I am with JD. Perhaps some Kubota folks, NH folks could chime in on their company's similar choices. I just mention this as a potential alternative. I have a JD 3720 and honestly if I did not do so much loader work and live where it is tight and very hilly, I would have gone thought seriously about a 990 machine, due to the horsepower/size to dollar ratio. I personally think they look good, too.
John M
John,
I may test drive a 790 but I am leaning a bit away from the gear drive trannys the more I mull it over. I have not spent much time at the Kubota dealership but the L3400 looks interesting. I agree with your comments echoed by others that I may be looking at too small a tractor.
   / Advice from tractor gurus #17
You have the same problem I had before I bought my B3030. These babies cost a lot of money and it is tough to decide on which machine is the right one for your needs. You have a big lot to mow and the advice to go with a larger tractor is correct. Don't go small. 35-45 hp at least to make things easy on you and the tractor. Ofcourse, money is allways part of the game.
   / Advice from tractor gurus #18
Yes, Chris, the prevailing opinion here is pretty much on. If you're looking to try to maintain your entire 18 acres then the tractors you've mentioned so far are on the small side. Could they do it....with a 5' cutter.....and a whole lot of seat time involved........uh, yeah, but you'd be pushing them and yourself to the outer limits to get it all done.
To me, it sounds like a Farmtrac/Mahindra/Zetor no-frills-but-lots-of-metal-and-guts rig is your ticket but as I do searches for dealers anywhere near your area of the woods it's coming up pretty lame. But, many of these tractors can be had brand new in the 35-45hp area for the money you're looking to spend.
It looks like you're going to have to decide between a smaller machine for working around the house and drive (and hiring the larger acreage stuff off) or a bigger rig and maybe a little more work on your part to handle it all.
   / Advice from tractor gurus #19
Yeah...we sure do give you a lot of things to think about, don't we?
Have you decided yet?
JCMSEVEN (bless his heart) mentioned the 790. It's true...I did sleep with this tractor for a while (since wifey kicked me out after buying it)...it's a great tractor...but at best, it's at the lower limit of what you'll need for 12-14 acres. I still think the Case would be the better buy for your needs and budget.
   / Advice from tractor gurus #20
Mornin Roy,
Good laugh ! Thanks ! :)
2015 Peterbilt 348 Dump Truck (A55973)
2015 Peterbilt 348...
84" HYD ROCK GRAPPLE (A52706)
84" HYD ROCK...
Wacker Neuson RD12 (A57148)
Wacker Neuson RD12...
1408 (A57192)
1408 (A57192)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
