Advice needed for trim mower
/ Advice needed for trim mower #1
amg280
Central NY
2011 Kubota B3000
Hey guys. I have an 8 acre property I mow with my tractor. There are alot of trees and ditches and culverts that I cant get close to with the tractor (with roll bar). Im looking for a decent self propelled little trim mower to get into these spots. Should I go out and buy a cheap throw away model, or get something decent like a toro, snapper, or ariens? Since it would be going into a ditch, and at weird angles, someone suggested an engine with an OHV.
Any suggesstions? So far Ive looked at cub (good prices), toro, and snapper.
Thanks for any advice.
Andy
/ Advice needed for trim mower #2
i would go to walmart and buy the cheapest or next to cheapest mower they have. When i grew up we would buy these and they would last 6-8 years cutting our yard there in the city but a big yard much bigger than these tiny subdivision lawns now a days. maybe a 1/3 acre lot? The motor never tore up (cut maybe every 2 weeks to week) the deck always rusted out cause it was rarely hosed out on the bottom and the wet grass rusted the deck out. Reason i say these is they are simple and little to go wrong especially if you are a good general mecanic. $100 mover lasts 7 years just trimming ditches thats good you probly will get more like 10-15 for just ditches) i would not go out and pay $300 on one that would see limited use even if you keep it 30 years thats still $100/10 years about the same as the cheaper one, yet you fork out all your mony at one time, ave the other $200 today and it will be worth more in 10 years than the lawnmower will be. If im confusing you i guess cause i kind of an economist, think about is a dollor today the same as a dollar in 20 years?
/ Advice needed for trim mower #3
I would would go cheap if it were me. I have a '86 tecumseh 5 hp 20" cut Craftsman that I still use for trim. Change the oil and keep the air filter reasonably clean don't let wet grass sit underneath and it will run for years.:D
/ Advice needed for trim mower #4
Go cheap but get the features you need and get a wide one if possible. You probably won't be using the catcher so look for one that has a good sized chute. Mine has a flap at the rear. It was not designed to be used without a catcher so I need to keep the flap open a few inches with a piece of wire or else the chute quickly clogs up and bogs down the engine. I also added some rubber to the flap to make it wider and lower, to prevent stones and muck getting thrown at my feet. It was a simple, cheap fix and works well.
Also check how easy it is to push and pull when its not being self propelled. These things don't have reverse gear so it can get very tiring pulling them backwards - something you will do quite a lot when mowing. And they usually go too fast to turn tight corners 'in drive' so you will probably have to manually push it forward a lot more than you think. (I have 2 self-propelled mowers and one is significantly easier to push/pull than the other - but both are much harder to push/pull than an ordinary walk behind mower.)
Big wheels are nice if you can get them.
Most seem to be 4 stroke, but don't be afraid of 2 stroke. They rev higher and are more powerful which is a help in long wet grass. (I have one of each). Mixing oil for the 2 stroke is a bit of a pain but the extra power is nice. (But the 4 stoke goes further on a tank which is worth considering if you are doing large areas.).
The drive on these things is usually just a rubber belt. Check to see what sort of protection it has and how easy it is to get at. My 'cheapie' used to throw the belt off the drive axle pulley when I hit bumps on slopes. I added a few washers to the rear axle mounts and slightly changed the angle of the axle. Again it was a cheap fix but a little frustrating til i worked it out.
My cheapie has 2 levers. One puts it 'in drive', the other is for the engine brake. I'm not sure how common this 'safety' feature is. The engine brake lever is real pain on a self propelled mower. If its released the engine stops. So I keep it in place with a simple plastic hand clamp. Again its a home made fix but thats the sort of thing you might have to do.
Edit. I see that some self propelled mowers are front wheel drive. I haven't used one but I'm guessing they would be absolutely hopeless on slopes. And check out how many wheels actually do the driving. You don't want it to turn into one wheel drive on the slightest bit of slippery ground.
/ Advice needed for trim mower #5
For mowing rough country I'd suggest a walk-behind string trimmer. They operate much like a standard lawnmower but will cut much taller grass and weeds and won't break the blade if you hit a rock. I have an old MTD unit and have it loaded with Stihl .105 commercial square line. It will cut some serious weeds and grass.
Several companies make these units, one is the Husqvarna HUS625HWT that sells for about $350.
If you're going with a traditional lawnmower I'd suggest a simple push mower, not self-propelled. I think you'll want the mower to be light and cheap, a throw-away. It will probably come with a B&S engine, and whether it's an OHV doesn't really matter. All the small vertical crank Briggs engines (push mower sized) use a splash system for lubrication (non-pressurized w/o an oil filter), and you shouldn't run them at extreme angles for an extended time, but people do. Keep it full of oil and change the air filter once in a while and it should give you 5+ years of service.
/ Advice needed for trim mower #6
I don't know anything about walk-behind string trimmers but I sure disagree regarding self propelled mowers. A cheap self propelled with a steel deck and no catcher is not heavy. I would never go back to using a normal mower for mowing rough areas, long grass or inclines.
/ Advice needed for trim mower #7
Andy
Sears has a couple mowers that are self propelled, no bagger and large rear wheels for $200. However wouldn't a weedeater string trimmer for the trees, ditches, and culverts be a better tool?
http://www.consumersearch.com/string-trimmer-reviews
/ Advice needed for trim mower #8
I would have to second the string trimmer on wheels. They are a beast and will cut through almost anything. The two I have are both 22 inch cut and will do just what a mower will do. Plus, when things get out of hand and stuff gets tall they will do what a mower would never be able to do.
/ Advice needed for trim mower #9
Even though I drool over commercial stuff like this> http://www.ingersolltractors.com/images/EastmanSpecSheets_011007LR.PDF Anymore, I'd go as cheap as possible for a trim mower. A Walmart special with a pulsa-jet carb'd Briggs classic. If you want, strengthen it up with a set of steel wheels and some big washers to keep them from ripping off the deck. If you have a "City" lot, by all means go out and buy a $400+ job.
Joel
/ Advice needed for trim mower #10
I use a 30 year old lawnboy to do my trim work. I found it in the bone yard of a small equipment dealer. It did not take much to get it running like new. 2 cycle has many advantages over a 4 cycle, less weight, no oil changes, and the old ones do not have the safety stuff that add weight and make hands ache holding the blade brake or engine kill switch while mowing.
/ Advice needed for trim mower #11
I have a cheap MTD "throw away" with a 4.5HP Briggs. It is basic engine/handle/blade/frame, with side discharge. I use it for exactly the purpose you're looking for and I'm very happy with it. I didn't feel it was worth it to go with a self propel or anything, as I'd rather stick with a lighter mower without any frills on it.
My dad had one just like it that lasted about 20 years mowing a bigger area.
/ Advice needed for trim mower #12
Thinking about this I guess the reason for the trend towards front wheel drive is that it allows a much larger grass chute to be maintained at the rear end of the deck. Both my self propelled mowers are rear wheel drive and they have relatively narrow rear chutes because half the back end is taken up by the belt drive mechanism. But in practice, even with a narrow chute, clogging is not much of a problem because in long damp grass I set the height high and rarely use the catcher.
As I said earlier, I'd be very wary of front wheel drive on a sloping lawn. I can imagine that when mowing uphill the weight transfer would cause the front wheels to lose traction VERY easily. Maybe someone with a front wheel drive self propelled mower could comment.
/ Advice needed for trim mower #13
I'll third that.:D When we lived on 10 acres, I bought the top of the line, electric start, DR timmer/mower. It sure wasn't cheap, but was a pleasure to use, even for my wife.
/ Advice needed for trim mower #14
How much traction they lose depends on how steep the slope is. Sometimes it is necessary to push them but it's still much easier than pushing a non-self propelled mower.
/ Advice needed for trim mower #15
I hadn't thought about that as the reason, but it makes sense. It did seem to me that the cheaper self-propelled ones are all FWD and the more expensive ones are RWD.
/ Advice needed for trim mower #16
A self propelled DR string trimmer is the perfect tool for such a job.
