Advice Needed. Sealing a Metal Barn Roof!
   / Advice Needed. Sealing a Metal Barn Roof! #11
Hi, What I do to older leaking tin roofs is coat the whole roof with aluminiumized roof coating, the type used on trailer roofs which are metal. Even if the tin has rusted holes in it it will fix it and makes a leaking rusty roof stop leaking and look like new again. Mixing 1 gallon diesel fuel to 5 gallons roof coating makes it spread best and improves its performance, I have used it both ways and with the diesel is best. If using on an flat house roof a little more diesel can be used, it will seal better and last longer with the diesel. Aluminum works better and last much longer than the black type.
   / Advice Needed. Sealing a Metal Barn Roof! #12
Just finished redoing all the screws in the metal roof of the house. They periodically back out and cause leaks because they are in the valley of the metal sheet.... not on top of the rib. Unknown why they back out.. perhaps because the underlying material is 1x4 pine... not plywood. Yes, the screws are the kind that have a rubber washer to prevent leaks. They unscrew and allow leaks.
I have had to do the roof several times now....
First time, I took out EVERY screw in a valley, put down a tar material using a caulking gun and replaced the screw.
Some backed out again in about 2 years. So for those I screwed them back in and put more tar on them.
This has occured ever few years now for about 15 years... here is what I have learned... best I can recall...
the regular, cheap roof tar hardens, doesn't stick properly to the metal, lots of leaks
the latex based tar gets brittle, cracks, leaks
The silicone material I used once has been excellent... only ONE screw has backed out so far.... and, it is very tightly adhered to the roof metal.
Most recently, I have used HENRY brand elastometric material from Home Depot.. about $7 a tube... it is ruberized and has fiber in it... during application, it is clear that it is superior to any prior stuff for adhering to the roof with the possible exception of the silicone. Reading carefully, this was the only material that indicated it could be used for metal roof fasteners...
My net... use either the best silicone material you can find... read the label carefully... or the HENRY material... there are several types of HENRY material... be sure and get the one that says it is for metal roof fasteners.
   / Advice Needed. Sealing a Metal Barn Roof! #13
As cheesy as this sounds.....My nails go through the top of the rib and there is a visible gap from underneath. I have a small can of black jack and some cheap stiff brushes. When I see an offending leak I go up from the underside and dab a glob of black jack around the nail where it meets the metal. It works really well for a minimum of effort. I am afraid that climbing around on top of the roof would only make things worse. I suppose if I had a really tall barn going at it from the inside would be more difficult. Now a days I have more trouble with condensation than leaks. A new metal roof won't change that.
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
1273 (A50490)
1273 (A50490)
2020 21" Exmark Push Mower (A52377)
2020 21" Exmark...
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
2019 New Holland Workmaster 95 MFWD Compact Utility Tractor with 632TL Loader - Poultry Special (A55302)
2019 New Holland...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
