OP
radman1
Elite Member
- Joined
- Jul 8, 2006
- Messages
- 3,016
- Location
- midwest
- Tractor
- JD 4520, Toolcat 5610, Bobcat S300, Case-IH 125 Pro, Case-IH 245, IH 1086, IH 806
Farmwithjunk
I don't have much road travel 2-3 miles of gravel at most. I didn't realize that laminated tires are that stiff on the road until you and others mentioned it. I have them on 3 pt mowers but never down on the road. I have an pull type old paddle scraper with airplane tires and they do seem to be very durable but require high psi.
I can't imagine pulling a 40' rotary mower. There would be no end to the number of things I would run into!
chh
I did a little research on the C/V driveline. Thanks for the explaination. It certainly seems like the way to go. We have a 20' older pull type flail mower without the C/V driveline and it requires relatively wide turns due to 1000 pto and chatter.
For anyones info, the standard U-joint driveline is called the Cardan type. A C/V driveline is also referred to as a "Double Cardan" driveline by some.
chh
