Advice on concrete slab
   / Advice on concrete slab #11
Don't forget a couple things when pouring your slab:
1. Welded wire fabric - contrary to popular belief this is not reinforcing. But, it limits shrinkage cracks (the small spider cracks). If you want a re-inforced slab (I doubt it), you need to go to 5" thick with #3 rebar mats.
2. Control joints. These are 1/2" deep grooves that are saw cut in the concrete the day after the pour. They provide a place for the concrete to crack. They are usually sawn from column to column like a checkerboard. ALL concrete will crack in a floating slab, but you can prevent that one large diagonal crack through your barn the spreads apart slowly for years. The control joints can be caulked with a commercial grade caulk.
Of course, you're in Texas so frost heave isn't much of a concern.
I can answer all construction related questions.
   / Advice on concrete slab #12
DON'T SET WOOD POSTS DIRECTLY ON CONCRETE.
I don't care if its glu-lam or pressure treated, eventually mother nature wins. Especially, with the new requirements in pressure treated wood---its not what you think for longevity.
Go to the Simpson Strong Tie website, or to Home Depot and get a post bracket that sets in the concrete and keeps your wood post 1" off the face of the concrete.
Sawn edges of pressure treated should be covered with tar.
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
2016 CATERPILLAR 259D SKID STEER (A51242)
2016 CATERPILLAR...
1982 LeeBoy Motor Grader (A52128)
1982 LeeBoy Motor...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
