Advice on Electrical Conduit
   / Advice on Electrical Conduit #11
Call an electrician. For now if you have an old inner tube you can wrap it around it. Being where it is you may need to have the power company disconnect power to fix it correctly, they may ask you for the name of the electrician doing the work. Either way you need to make sure that the wire inside the box has enough play otherwise you could do real damage. It's possible that you could pull the wires free from the other end and start a fire if they short out. It should be a quick fix so it shouldn't cost too much but better safe than sorry.
Well, I did call my electrician who came out yesterday evening to evaluate--great guy and I highly recommend him.
We are going with the flex line. Supply warehouses in this part of the country don't even stock the expansion joints. Also as dstig1 mentioned, we are actually seeing movement in mulitple directions (the conduit no longer lines up), so the flex line will work better for that issue.
As a side note, the panel has a 200 amps breaker and feeds through to the barn. The wire the previous owner used to the barn is only rated to 150 amps, so I am having a 100 amp breaker put in to protect the line feeding the barn.
The joys of country livin'.
   / Advice on Electrical Conduit #13
Better safe than sorry. I'm a do it yourself kind of guy but sometimes having a professional come out is worth it.
UNUSED RAYTREE RMBD50-50" HYD DRUM MULCHER (A57193)
UNUSED RAYTREE...
6' Fork Extensions (A56469)
6' Fork Extensions...
2013 KUBOTA RTV900 XT (A57192)
2013 KUBOTA RTV900...
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2002 Chevrolet S10 Pickup Truck (A55852)
2002 Chevrolet S10...
