Advice on replacing bearings on 3 pt. disk
   / Advice on replacing bearings on 3 pt. disk #1
pharmvet
Platinum Member
North East TX
Ford 7710 II FWA, NH TB110 FWA w/ NH 46LB loader, JD 5303 2wd w/ loader
Im in the middle of a re-furbish project on a 10' 3 pt. Poplarville disk (pics later if anyone is interested). As with all things, those who have done a task many times will often have a few gems of wisdom that will make the project go more smoothly. This weekend I will be putting the axles, disks, spools,blades, bearings together. The bearings fit between 2 flangetts which in turn bolt to the hanger. My plan was to leave the 4 bolts holding the 2 flangetts together (Also bolting the flangette / bearing assembly to the hanger) slightly loose. I then planned to bolt the hanger to the arms after all parts had been placed properly on the axle. I thought I would then spin the axle and let the bearings "settle" into the proper location between the flangetts before I put the final tightening on the 4 carriage bolts holding the 2 flangetts together and fastened to the hanger.
I thought this would be the best way, because I noticed that the bearing does not fit in an exact location between the flangettes and therefore if I tightened everything before I put it together and before I spun the axle, I assumed there might be some binding.
Any words of wisdome here?? thanks
   / Advice on replacing bearings on 3 pt. disk #2
The sperical OD bearing in flangettes is termed to be self-aligning so it really shouldn't matter. The way you described, get everything assembled and tighten the bolts on the flangettes last, is the nearest thing to perfect alignment to start with so it can't hurt. Whenever I assemble a shaft with flangette bearings that is the way I do it if possible - tighten the flangettes last.
   / Advice on replacing bearings on 3 pt. disk #3
I too am in the middle of a rebuild. My cast bearings have a spool and the hanger/caps. Seems like there is some kind of bushing material in there that reminds me of some kind of carbon/graphite stuff. Anyone know what that is called? should I just clean them up a bit, throw some axel grease on 'em and replace the parts as discussed above?
Thanks
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
2022 JOHN DEERE 744L WHEEL LOADER (A60429)
2022 JOHN DEERE...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 New Holland CR10.90 Combine - 330 Engine Hours - 251 Separator Hours (A56436)
2023 New Holland...
1982 LeeBoy Motor Grader (A55302)
1982 LeeBoy Motor...
