Advice wanted on installing pipe culverts in woods roads
   / Advice wanted on installing pipe culverts in woods roads #11
The pipe in the picture is too small for any creek or draw. It will clog with debris with any significant rain
Proper backfill is the most important ingredient to a long lasting culvert
   / Advice wanted on installing pipe culverts in woods roads #12
If you can arrange it in your terrain, I like a low maintenance, non-clogging, concrete bottom ford.
Bruce
   / Advice wanted on installing pipe culverts in woods roads #13
Bruce
Aka a concrete low water crossing .... I agree
   / Advice wanted on installing pipe culverts in woods roads #14
Metal or plastic pipes will fail if the culvert cover is not done right. If it is done right, plastic will greatly outlast steel. So it has become the material of choice nowadays.
Concrete is a different ball game, as you need larger equipment to handle and position it compared to steel or plastic. It does have its own structural strength, so it's less vulnerable to poor fill. However, it will fail too under insufficient cover. When houses are built around here, the site crew normally drops a concrete pipe in the ditch and back fills with just enough stone to reach the top of the pipe. Then all the construction traffic pounds on that pipe. After a few months, they all develop cracks or have chunks missing. Even seen a cement truck get stuck when a concrete pipe gave way.
So whatever you use, be sure it's bedded and back filled properly, with the correct amount of cover.
I put my culvert in about three years ago, using plastic pipe with proper prep, backfill, and cover. Basically, did it as a permanent job from day one. It handled all our construction traffic with no issues, and has outlived all the other half-a$& concrete culvert installs on the street. I would not hesitate to use plastic again.
You are correct with the requirements of proper backfill. My plastic culvert was perfect for 6 years and then had settlement under it which caused it to fail overnight. Mine was very deep so it had a lot of overburden weight working against me. My plastic one at the road is just 1 foot under and is holding up nicely.
   / Advice wanted on installing pipe culverts in woods roads #16
Center for Dirt and Gravel Road Studies
Several helpful technical articles here.
In my opinion, this is the most important quote from your link. This was not done when mine was installed and it failed. It was a $1500 mistake in my case.
"Compaction of the first layer of bedding material is crucial because it packs material down around the base of the pipe for support (See photo D). The importance of compaction cannot be overstated! Unlike metal and concrete pipes which have structural strength, plastic pipes get their strength from the material compacted tightly around them."
(APPROX 7) 10" I-BEAMS UP TO 12' (A54756)
(APPROX 7) 10"...
2008 INTERNATIONAL WORKSTAR 7400 SFA 6X4 DUMP TRK (A51406)
2008 INTERNATIONAL...
UNUSED LANDHONOR HPF-11-3000G HYD PALLET FORKS (A54757)
UNUSED LANDHONOR...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A55788)
2012 Mack CXU613...
Electric Mobility Scooter (A51694)
Electric Mobility...
