Aerator - how tight on the turnbuckles
   / Aerator - how tight on the turnbuckles #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I have a 48" Midwest aerator, how much sway is ok when your using the arerator. Do you want the turnbuckles tight so you have next to no sway? I have the pins mounted on the inside on the aerator since I'm pulling it with a BX230.
   / Aerator - how tight on the turnbuckles #2
When using a box blade I broke the turnbuckle on one of my sway chains. I was told that the sway chains need to be tight enough to keep the implement from swaying excesively. I was told to keep them tight while allowing enough movement for any changes when the implement is up or down.
Eric
   / Aerator - how tight on the turnbuckles #3
I have a 60" aerator. I run the chains tight, but be sure to raise it every time you turn. It becomes a tiller if you don't.
2003 STERLING ACTERRA FLATBED DUMP (A51222)
2003 STERLING...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2013 Ford F-250...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
2007 GMC Acadia SUV (A50324)
2007 GMC Acadia...
2022 Western Star Tri Axle Dump (A47384)
2022 Western Star...
