Aerator - how tight on the turnbuckles
   / Aerator - how tight on the turnbuckles #1
Scrounger
Platinum Member
Bethlehem (Lower Nazareth) PA
Kubota BX2230
I have a 48" Midwest aerator, how much sway is ok when your using the arerator. Do you want the turnbuckles tight so you have next to no sway? I have the pins mounted on the inside on the aerator since I'm pulling it with a BX230.
   / Aerator - how tight on the turnbuckles #2
When using a box blade I broke the turnbuckle on one of my sway chains. I was told that the sway chains need to be tight enough to keep the implement from swaying excesively. I was told to keep them tight while allowing enough movement for any changes when the implement is up or down.
Eric
   / Aerator - how tight on the turnbuckles #3
I have a 60" aerator. I run the chains tight, but be sure to raise it every time you turn. It becomes a tiller if you don't.
Land Honor Quick Attach Power Rake (A50514)
Land Honor Quick...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A52128)
2004 Capacity Yard...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2002 CASE INTERNATIONAL MX270 TRACTOR (A51243)
2002 CASE...
UNUSED FUTURE FT-E48 ELECTRIC BICYCLE (A51244)
UNUSED FUTURE...
