Ron D.
- Joined
- Apr 23, 2009
- Messages
- 110
- Location
- Collin Co. Texas
- Tractor
- 2003 Kubota L2600DT, F13D Yanmar, Sears garden tractor with MMM, older JD Garden Tractor with MMM, Gravely commercial ZTM
I've read several posts about aerators and wanted to share my recent experience and opinion. After reviewing the aerator threads, I would have liked to have bought a 3 point set-up. However, even the reasonable ones look to be over $600. I'm aerating only a few times a year on my 1.5 acs, so it was hard to justify the cost when you need so many other things (like a tiller, carry-all, etc), so I opted for the Agi Fab sold at TSC and Lowes. It came unassembled and it took about 1.5 hours to put it together. The quality is better than expected, all the parts were there and the assembly instruction were excellent. It carries a 2 yr limited warranty.
It is a 4 foot unit that can accomdate an additional 170 lbs of weight. We have several large dogs and the back yard was very compacted. I loaded it up with weight and knocked out the yard in about a day and a half. That included going over the same areas several times. I had to go very slow to ensure maximum penetration, but I'm very happy with the results. I used it the day after it rained, which helped penetration. I believe this unit will last several years and at this point I'm glad I didn't spend the additional dollars to get a higher end unit.
Later, I still hope to purchase a 3 point setup. It would be clearly more manuverable than a pull behind, but with a little extra work the pull behind worked well.
I hope this helps some of you that are going through the same analysis I went through. I would recommend this as something that will get you by for several years if you don't want to spend more money.
