/ After swapping coil,pulser coils,spark plugs,and connections no fire on left cylinder
How can one reverse wires the wires coming from coils but keep valve and fire timing in sync ?
Switching wires from module to coil is straight forward but won't coil pulsars wires feeding module have to be switched also?
In effect by switching the working channel module is bring used,if left side is bad?
The work I did was replacing water pump last year and cam gear this year and it's basically the same tear down,remove crankcase cover,and only battery and ground on the crankcase connections are taken loose.
So I can't see any work done causing problem to ignition.
To keep it simple I pulled spark plugs,switched wires at plug in module going to coil,and checked fire at plugs so I didn't have to worry about timing and backfiring.
The left side fired and the tight side didn't so it's indeed the black box or ignition module.
Now to find one or maybe I'll get lucky and it's just a zener diode that blew or cracked from vibration.
The black box needs to be mounted or wrapped in foam rubber to protect it from vibration.
I've already seen three cracked resistors on board in black box.
