Nothing against hand filing at all other than it's time consuming and dull cutters really take time to get sharp.  I have a Timberline clamp on the bar tooth sharpener as well (that I'm giving away now).  The Oregon grinder isn't a cheap date ($209.00 on Amazon with free delivery) but it very consistently sharpens each tooth plus you can set the rakers with it.  Comes with 3 grinding wheels (also available on Amazon or from Oregon direct or your local chainsaw shop), a dressing stone (to maintain the correct radius on the wheels) as well as a radius gage and raker gage and the correct Allen wrenches for changing the wheels.
Oregon offers 2 models, the one I bought with the manual clamping vise and a more expensive one with a hydraulic vise (that I don't need).  The aluminum castings are very nice and well machined and powder coated.  Overall fit and finish is top shelf too.
Initial set up takes some time as all the grinding angles are adjustable but once it's set up, all you need to do is dial in the appropriate angles and change the wheels for various chain pitches.  It sharpens all pitches, from 1/4 low profile
chipper to 404 skip tooth.  Of course it won't sharpen square tooth
chipper, that is always a hand file chain.
No matter how good you are at hand filing, consistent tooth sharpening is always an issue.  With the Oregon, every tooth is ground equally and setting the rakers is simply a matter of changing wheels.
I agonized over buying one for a long time but I finally sprung for one.  Glad I did.
