Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 51,575
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
I use ag tires on all my tractors except one.. and it has turfs on it. ironically.. it tears up the yard wores thent he ag bar tires, as the one with turf tires is the one that breaks traction and spins, making a burned spot
if you have super soft topsoil, or it's real wet like peat.. it will print.. but regular dirt / pasture shouldn't be too bad..
soundguy
soundguy
I have read alot of comparisons before buying my 2610 and bought the machine w/ the AGs already on the unit. I also purchased a set of R-4's, both sets loaded. However, I am still waiting for the R-4's to come in. I have been using the Ags for a couple of weeks now, and here is what I experienced.
They bite really good and in 4 wheel mode in turns I haven't noticed a bad tendency to "tear-up" the turf, even in wet conditions. I have used them on hills and flat ground. I have noticed the bars seem to "track" the turf, but seems to go away after a day or so. This may become worse as time goes on, and repeated use. I have been to the point where the tires will dig into the turf on steep side-hill use, but so does the turfs on my Z148 Gravely. This machine out weighs the Z148 by about 1000 lbs. So, I will see if I need the R-4 set, since I already bought them. It has been very wet here so I have not tried the Ags w/ the BH or rotary cutter yet. I do not see the R-4's working as good sidehilling because of the "straighter" tread, I would think they would tend to slide more than the Ags, due to the angle of the tread. I will see when I get them. Anyway, this is just a early review of my experience to date.
