I did what you suggested and got into the site.
I found the fuel shut off solenoid and a diode. Both were illustrations or sketches so of little help except to confirm the solenoid has 3 wires and the diode is present.
Thinking Ago did not invent the fuel shut off solenoid I started to look elsewhere for an operating description.
As I see its operation and its three wires, one wire is a ground wire. Is it obvious which one it is?
The other two are two different sources of 12 volt power. One is a low amp one that is powered anytime the engine is running from the run position on the ignition switch. It may have a smaller diameter wire. Is there one wire smaller than the other(s)?
The small wire, assuming one is smaller, goes to the run position on the ignition switch. Once the solenoid has been retracted using a large amount of amps fed from a relay, when the key is returned to the run position, the low amps wire takes over to hold the solenoid so the engine can run.
The high power wire is triggered by turning the key to the start position. The wire from the start terminal on the key switch does not go directly to the solenoid but rather a relay which in turn will send the large amps to the solenoid to get it pulled in all the way at which point the run position and low amp circuit take over.
My suspicion is that the relay which powers the high amp wire has stuck contacts and is continually sending large amp power to the solenoid long after it should have stopped thus cooking the solenoid from the constant high amps going through it.
Do you know which relay powers the fuel solenoid?
I need to hear from you on this before advising you further.
Dave
M7040
