Age old debate, which truck & motor
   / Age old debate, which truck & motor #21
I miss the 8' bed I had on the 71 ford pick up for hauling things like 12 14 and 16 foot lumber and my 24 foot extension ladders.
Any idea how long a standard cab 8' bed 3/4 or 1 ton is.?
Just wonering if in would fit in my 22 foot deep garage stalls.
A little over 17ft. It will fit ok in a 22ft garage as long as the front of the garage is empty in front of the truck, and you do not leave the receiver in your hitch. I consider fit ok to be able to walk all the way around it with the garage door closed without having to turn sideways to get around it, as well as being to open the gate with the garage door down.
   / Age old debate, which truck & motor #22
*A little over 17ft. It will fit ok in a 22ft garage as long as the front of the garage is empty in front of the truck, and you do not leave the receiver in your hitch. I consider fit ok to be able to walk all the way around it with the garage door closed without having to turn sideways to get around it, as well as being to open the gate with the garage door down.
* thanks.
   / Age old debate, which truck & motor #23
I'm not looking new only I'll gladly buy a lightly used unit. I've heard the 6.4's are quite fast and there also quiet.
Matt
The last time you and I were in a thread together discussing Ford & GM, it got quite heated. I remember some pretty hurtful stuff being said.
I own/operate a GMC3500 in work conditions everyday, so I believe I have a good deal of credibility.
Just like the Ford was previously mentioned to have better towing capacity numbers, the GM has better HP/torque & drivetrain package.
If you look at the performance of both trucks, the DMAX makes considerably more torque at lower RPM than the 6.4L (and much more than the 6L)-even with its' twin turbos. If you want to move a load off the line, high torque at low RPM is what does the job. Both the 6L & 6.4L diesels like to rev higher than the dmax to make torque and that causes more wear on the engine and more fuel consumption. The nice thing about the dmax is it does it with a simpler, single turbo engine. Ford's 6.4L with twins can't match dmax's performance & grunt torque with a single turbo.
*That's not a brand warfare opinion, that's a fact any objective trucker or mechanic will tell you about any diesel engine comparison. They will tell you that a diesel powered truck is better when it makes more torque at lower RPMs and has been my real life experience with small & larger diesel trucks I own/operate.
As far as the transmission, the GM has advantages over the Ford & 68RE dodge transmissions. GM & Dodge has 6 gears over Ford's 5. Anytime you can add an additional gear, it keeps the ratios between gears tighter. Ever notice that most (not all) trucks as they get bigger have more gears in their transmissions? Ever wonder why? The simple reason is that it keeps the engine in it's powerband better and lessens fuel consumption because the RPMs are kept lower. Look at GM's reverse gear sometime compared to Ford's and see how much stronger it feels when backing a trailer though dirt & mud. Add to that the manual shift feature and the 100,000 mile warranty and the Allison name and I really don't see how the others could be better than GM.
*Again, not a brand warfare opinion, just a common sense "diesel trucker" logic applied to comparing these transmissions.
The rear axle in the GM is another place to compare to Ford & Dodge. Ford 's SRW has a 10.5" axle. GM's is 11.5". Forget the brands for a moment. Which size would you rather have? 11.5" or 10.5"? Dodges is 11.5", but doesn't have the G-80 locker. The G-80 locker must be owned & used to be appreciated. Pavement queens don't ever really need a locker, but once you step off the pavement, this thing is nothing short of amazing compared to a traditional Ford limited slip rear.
* Once again, not brand bashing or anything emotional-just a comparison of size and feature 11.5" is bigger than 10.5". A true locker lasts longer and locks better than clutch packs. Ask a real dump trucker if he'd rather have a bigger rear ring & pinion or a smaller one in the rear axle. Then ask him if he'd rather have clutch packs rear or a locker.
I also like gauges have a wire that goes to an actual sending unit over dummy lights found on the Ford, especially the transmission gauge. Just like a bigger Allison found in a concrete mixer, the smaller ally has a real proportional gauge & sender. Ford doesn't. In bigger trucks, sending units are favored over dummy lights, like found in a car and Ford trucks-don't know about Dodge.
I know this is a Ford dominated website, but that's my take on it. Ford does have heavier spring packs and that's a legitimate advantage, but since the tires are the limiting factor in most cases, is it really that big an advantage? Ford may have heavier GVWR's, but most of the extra capacity is in the front axle, not the rear axle. GM's front axle is typically rated at 5,000 lbs. Ford's is more like 6,000 lbs. That's where the bulk of their payload superiority is found. Other than a snowplow, how much payload goes on your front axle? Most goes on the rear axle where GM is fairly close in rear axle capacity. Ford's SRW is rated at 11,200lbs. GM is 9,900 lbs. Apparently a big advantage to ford, but most of Ford's capacity advantage is in the 1,000lb difference in front axle rating. That leaves only ~300lb advantage in the rear axle. Remember that Fords weigh ~500lbs more than GM, so those advantages may actually be even less!
If you bought a GM, I bet you'd love it. Brand loyalty is a strong emotion that keeps people in trucks. The big 3 know it and depend on it for sales. I was Ford brand loyal for 15 years and decided to open my eyes back in '07 and see what the GM guys were so proud of and now I know. In '07, IMO, GM built a better truck and still does right now. That may change and the next truck I buy, I will compare all 3 and buy the truck that I feel is the best. Brand loyalty is so stupid, but it's good for business and really keeps the websites busy with all the arguing over which truck/tractor/widget is better.
   / Age old debate, which truck & motor #24
I have felt the tone of the thread--even from the Ford guys like myself--has been good and largely non-polarizing. I for one, have tried to give credit to the GM and Dodge products where due. I would encourage our OP to drive all three brands--as no amount of numerology can diminish how comfortable one feels actually driving the truck, and this is not wrong. I have also mentioned to our OP that he may wish to consider other brands, though it seems his primary questions have been regarding the Ford 6.4L, so it seems his comfort level might be higher with Ford products and justifiably higher with the deep tank that particularly GM and Dodge are sitting in now. Ford is also in this tank, but is keeping its head above water better. I can PERSONALLY attest that the supposed increased power of the Duramax does not help it in performance, at least in the example(s) I know. My PSD 6.4L is every ounce as good a performer as any stock Duramax truck I have ever seen or used either towing or empty. If I had felt the GM product to be a substantially better product, I would have bought one. My current 6.4L is one of only three Ford products (one a hand me down) I own or have owned in the past 6 years, so I am not paid by nor married to Ford products. On the contrary, I have owned more GM products in this time than Blue Oval, though none diesel. In the past, I have expressed agreement with Builder on the rear axle differences and I do wish the Ford had an additional gear in the tranny as does the Chevy and Dodge, but on the road, the Ford performs well. It also has failed yet to implode as suggested it might by certain forum members nearly two years ago. The "twin turbos" which actually is a dual vane sequential turbo, not a true "twin", has proven to be fine. With better coolant flow, water jacketing, and stronger lower end in the PSD as examples, I suspect the reliability advantage of a single turbo setup is nullified. If it is unchanged as has been before, the comparisons made when "the light was seen" about GM products were based on older products from Ford, and not a true apples to apples comparison based on the most-updated models offered. I had a 2002 PSD with the Banks PowerPack, and it was fast and had a lot of power. I also cannot compare it with regard to smoothness, drivability when empty or loaded, or several other performance categories to my current truck--there simply is no comparison. Thus, if one is comparing a 1999 (did I get the model year correct??) to a 2007 truck, there SHOULD be a difference. There are many points with which I agree with with our GM contingent, but it is not so clear the GM product is unequivocally superior. I think each manufacturer makes a solid truck these days and ultimately it will boil down to which way our OP wishes to go and which company he feels offers the best deal and likely longevity. I think to imply though that the Ford 6.4L engine is not a solid and competitive engine and has inherant design issues which make it less desirable is not accurate. It is a fine powerplant. So, to our OP--the 6.4L is fine. It will NOT explode, it is quiet and powerful. It likely makes substantially more HP and torque than its rating and has plenty of towing power. It will likely get within one mpg in most cases of the GM Duramax in empty and towing situations. The size, weight, and features of the Ford product are tough to beat. The GM product has the advantage in rear axle (though they did not have TCS which Ford did when I was looking--they might have it now to keep pace) and transmission. Frame, axle, and suspension are heavier in the Ford, but it does not handle as well--especially unloaded, as does the GM product. It will ultimately boil down to which features matter most to you, but the engine would be of no concern to me.
John M
   / Age old debate, which truck & motor #25
Builder, I agree with most of your info. The GM drive train is a good one now in the later model year trucks. There are a few facts you do have wrong. The Ford SRW F-350 on my truck is 11,500#, not 11,200#, not a big deal but just giving this guy the facts.
Also you will argue this until you are blue in the face and so will I but the Ford Torque Shift is a 6 speed tranny. Granted it only uses 5 gears depending on outside air temp or if its in tow/haul mode. So actually Ford was the first of the Big 3 with a 6 speed. I know they only use 5 but its still a 6 speed tranny. Again just the facts as you say.
Also I do not see where you get the "Dummy Light" thing. Both my 04 and 06 have a Tach, Spedo, Oil Pres, Water Temp, Trans Temp, Fuel Gauge, and Boost Gauge. No dummy lights for these primary functions. It does have dummy lights for things like low fuel, check engine, ect. But all the other functions like Tranny Temp have a gauge. Again just the facts as you say.
Either way I still think the guy should keep what he has for a year and see how the deals go. Just remember if you buy it cheap 9 times out of 10 that gain will be lost in the next 3-4 years on trade. Look at the Chevy Trail Blazer 6 cylinder 4x4. You can buy them all day long around here for $10,000.00 with 60,000 miles. I was just at a dealer this morning. He has dozens of them all alike, over 35 or more, he bought sight unseen from GM. He said they are not worth anything because they had great deals and flooded the market with them in 04 and 05. Same holds true for the Ford Escape, another local dealer has 60 plus he got from Ford. Most have under 40,000 miles and its take your pick $11,777. All are 4x4 V6. Simple supply and demand. The market gets flooded. There is no free lunch.
Chris
   / Age old debate, which truck & motor #26
Pitt, what ratio's do you have? What are you towing with it? I'm not too wooried about the engine other than the twin turbo's. I would never have been turbo shy but most 6.0 owners are so not so much because of turbos in general being an issue but because varible pitch veins can be with oil coking. Are the 6.4's varible? The fit and finish of the fords is hard to meet but the gm's ride much better for day to day. I don't plow so the soft gm fronte end isn't an issue. What's the story with duramax injectors? I hear from time to time about issues with them andy truth to it or is it internet gossip?
Matt
I have the 3.73 ratio limited slip axle. The mpg numbers I listed are empty if I didn't say that already. I tow our two horse's around so they can buck us off in different parts of the country. I do not have numbers yet towing the horses as everything is still frozen solid here in MN.
   / Age old debate, which truck & motor #27
Hey guys first and foremost I don't want this thread to get into a brand war I would just like some constructive replies.
Matt:D
1) This will happen no matter what you ask.:D
_____________________________________
Last year after camping season i sold my 05 F-250 diesel because it didn't have a auto tran. and was a king cab, and I'm planning on buying a new F-250 diesel crew cab with auto tran and don't plan to ask anyone for advice, the reason because i want a truck that i will be satisfied with, not to satisfy someone else.
I have a 03 F-150 king cab that looks and runs as good as the day i bought it, and only has 41000 miles on it. So i am just waiting for the right F-250 and waiting to see what the prices come down to and shopping different lots so i don't have to order again.
So the way i see it, whatever you have in mine whether it is a dually, gas, diesel, crew cab, king cab, or any other brand, you should make that decision so you will be satisfied with it.
   / Age old debate, which truck & motor #28
X2 :D
   / Age old debate, which truck & motor #29
Very good point. It would take a lot of arm twisting to get me to change my mind and the 2 times it happened I was disappointed. Get what you like. That is why there is different brands with different mind sets on building trucks.
On that note you should really also consider a SRW F-350. A lot more truck for about $600 more. There I am telling you what to buy.:D:D:D
Chris
   / Age old debate, which truck & motor #30
It's kinda hard to have this discussion with out biased opinion, even though OP hoped it wouldn't become a "brand war"
Luckily folks here on TBN are extraordinarily civil towards each other.
I will say again, if you don't need a pick-up bed, look into the Dodge cab/chassis, it just came out 2 years ago and with dismal economy and commercial truck sales in the dumps, most people know nothing about them.
It's got the 6.7 Cummins (nuff said?) and a new "to die for" 6 speed tranny (AISIN) yes it's Japanese, but once you get over that it's supposed to make Alison look like a toy. Now I know that will ruffle some feathers and I'm not a gear-head so I don't have all the specs for comparison, it's just what I've heard from those who are supposed to know.
We are all biased and when you spend $50,000.+ for something then you want to think you made the right decission, it just human nature.
JB.
2025 New/Unused Wolverine Auger Drive and Bit (A51573)
2025 New/Unused...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
Generac 5000Watt Heavy Duty Diesel Generator (A51691)
Generac 5000Watt...
New/Unused 7ft Workbench (A51573)
New/Unused 7ft...
