I was just given an Agric tiller built in 1997 in Italy according to it's tag but there is no model number. It's been setting for 4 years and seen it's share of abuse but works great.
1) I looked for a place to drain the oil and replace but can't find one. Do most tillers have sealed oil that can't be replaced without taking the case apart?
2) The only place to lube seemed to be one zirc by the chain enclosure. I pumped about 4 times and the grease gun didn't get hard. (No comments please). I was afraid to put more grease in because I was afraid I'd blow some kind of seal. What do you think?
3) There were 2 small caps, one on top of the tiller and one on the side but neither had a screw thread. When I lifted the caps off there was a tiny hole under each. The holes were small and didn't look like anything could be filled there but was more like a pop off of some sort. Anyone seen something like this.
4) The tiller size is 48" but has about a 1" protrusion on each side. It has 5 rotors with 6 blades on each. It's very heavy duty. I'm pulling it with a Kubota B7510 which is 21hp. At the rpm speed of 2600rpm it appears to pull OK but I jusr want to make sure I don't hurt the tractor. I pull it very slow. Any feedback about that would be appreciated.
Have a great holiday.
Harris
Harris
