Air Blow Guns
   / Air Blow Guns #11
The Typhoon Pro guns do a great job and are well made if you have the volume. I have a 12?" and a 6"
   / Air Blow Guns
Are they a venturi style? Never owned one like that.
Boy, looked at them. The last time I saw instuments like that, I was strapped to an alien examination table! lol
   / Air Blow Guns #13
WoW!!! If they made a 16 oz. portable compressed air cylinder and a holster....... Strap that Multi-Jet unit right to my hip!! Their design engineers are taking clues from Star Trek and similar SiFi flicks. And the cost is............??
   / Air Blow Guns #14
I have blow guns just about everywhere I need to use one but the one that gets the most use is one I made.
I took an air compressor quick-connect male plug and a female plug, and screwed them together.
I get a lot more air out of it than any blowgun I have ever used.
My compressor makes about 15 psi, but it can't quite keep up. But with that high volume, the mess is cleaned up much faster.
I call it my pneumatic broom.
   / Air Blow Guns #15
I've got several of the old style cast metal ones. Since they have threaded ends I put in some AN fittings and have one that has a 3' section of brake line with a bend at the tip for floor and behind stuff cleaning, one with a 8" straight tube for general use, one with a 90 degree fitting for radiators and such, and a rubber tipped one for things like emptying out a pressure washer hose where you need a positive seal.
   / Air Blow Guns #16
Sooo...... I picked up a Typhoon blow gun from House of Hose in Spokane this morning. It is MANY magnitudes superior to my home made one. Pull the trigger - it actually has recoil. Now I have to find one of my disposable dust masks and I can blow all the sawdust & crap out of my work shed.
I got the model with the 12" extension. I ran my compressor at 100 psi. $24.95
   / Air Blow Guns #17
That sounds like a good deal to me. I'm sure I had the privilege of paying more. Though I have to say, "The House of Hose" seems like a place my ex sister in law might of worked...
   / Air Blow Guns
You must be confusing that with "House Of Hose Bag". Common Mistake.
   / Air Blow Guns #19
You must be confusing that with "House Of House of Hose Bag". Common Mistake.
Probably not owned by the same guy? :laughing:
BTW, if you guys need GREAT flex hoses, go with the Coilhose Pneumatic too.
UNUSED JCT 72" HD BRUSH CUTTER (A51248)
UNUSED JCT 72" HD...
2013 John Deere 824K (A53472)
2013 John Deere...
50ft Fuel Line (A51573)
50ft Fuel Line...
Set of AG R4 Wheels and Tires (A53472)
Set of AG R4...
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
