tallyho8
Elite Member
- Joined
- Aug 1, 2004
- Messages
- 4,533
- Tractor
- Kubota L4400, Kubota ZD326
I use an analog ohm meter to check capacitors. Touch the 2 leads to the 2 terminals and the needle will jump very high and then settle back down if the capacitor is good. If the needle doesn't move, or shows continuous continuity between the 2 terminals or one terminal and the case, the capacitor is bad.
PS: You must disconnect the leads from the capacitor before testing.
