Mowing Air ride seat on a zero turn?
   / Air ride seat on a zero turn? #1
mikester
Elite Member
Canada
M59 TLB
I love my ZD326 but on rough ground the suspension seat is a back breaker.
Has anyone here tried installing an air ride seat on their zero turn? I'm looking for links to seat and suspension suppliers.
   / Air ride seat on a zero turn? #2
Following this, could be a good upgrade on my 54" ZT....
   / Air ride seat on a zero turn? #3
They do make just the air suspension that you use your own seat. "Little cheaper" . The whole unit gets pricey. Probably $600 and more. They do look nice though.
   / Air ride seat on a zero turn? #4
The air carriage thats used on the ZD1511 can go over to other models. Not sure on the ZD326, but it may fit.
   / Air ride seat on a zero turn? #5
The new Hustler Super Z HD I bought last spring came with a Grammer air suspension seat. I have some rough lawn and the air seat is a lot better than the spring suspension seat I installed on my old Hustler Z. I have chronic lower back problems and the air seat really helps. Many zero turn mowers have a common seat mounting bolt pattern, so a replacement seat is a bolt on install. The air seats are expensive, but to me very worth it if you have rough ground. Vic
   / Air ride seat on a zero turn? #6
I'm assuming you have adjusted your spring tension on the seat to balance your weight? The seats on the ZDs I think are some of the best seats Kubota has. You must be running over some very rough ground!!
2017 Ram 4500 Bucket Truck (A52748)
2017 Ram 4500...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A52748)
2022 Gravely...
2015 RAM 5500 Bucket Truck w/ Versalift SST40 boom -Cummins Diesel - Auto Trans- 4X4 - 72096 miles (A52748)
2015 RAM 5500...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
2015 International ProStar Truck, VIN # 3HSDJAPR0FN618550 (A51572)
2015 International...
