Seems that some manufacturers, especially those making cheaper break barrel guns, engage in a "fps" (feet per second) velocity race. Some pellet mfgs do the same with their lead-free pellets - hawking the fact that their pellets are faster. No surprise as quite naturally lighter alloy pellets go faster, but that's not necessarily better if accuracy and performance take primacy.
Besides not carrying as much energy downrange, lighter pellets that break the sound barrier (approx. 1,125 fps @ 68F and sea level) are often less accurate due to the instability imparted to the pellet due to the trans-sonic and supersonic shock waves. The pellet will also be nosier as it produces a ballistic crack until it drops below the speed of sound. Oft times a heavier slower pellet (in the range of 900 - 1000 fps or so) will impart more energy to the target and with more accuracy. Common advice is to experiment with different pellets to find one your gun "likes". Unfortunately, as CA and probably more states ban lead, obtaining accurate and efficient pellet and rim fire ammo will likely be more difficult.
bumper
If the scope is mounted on the barrel of a break barrel air rifle the movement of the barrel would not affect accuracy would it?
We have used a .22 for stunning hogs and big beef for slaughter. Modern pellet guns are impressive but if I had a choice I'd never consider using one for this. A good used Marlin model 60 (preferably an older one) would cost you about $125 and last for many years. What do these high powered pellet guns cost? If I had to run for my life I'd want a model 60 and some ammo with me. Happy hunting.
But, common sense tells me that sound is just that 'sound' and has zero impact on actual trajectory.
A friend brought a .177 Gamo Big Cat 1250 Air Rifle with 4 x 32 Rifle Scope to the ranch... it's a breach made in Spain I think...
So far it was not impressive.
The squirrels went down and then got back up, gave the finger and scampered off... at least it sure looked like we were getting flipped off... ;-)
Range about 25 yards...
