All threads marked read in each forum!
   / All threads marked read in each forum! #1
Henro
Elite Member
Few miles north of Pgh, PA
Kubota B2910, BX2200, KX41-2V mini EX
I mentioned this in another thread here, but now I am sure this is happening.
If I go into a forum that has multiple threads showing unread posts, and read one thread, then I came back out of that thread by clicking on "index" all the remaining threads show as read, and there are no longer any unread posts in any thread.
I tested this by going into a forum I never read, and the same thing happened there.
When I go back to the main index, I get "Welcome back henro" which I think was always there. I do not get logged off from what I can see, but maybe that is somehow happening and I get logged back on automatically when going back to the main index...
Just a report for anyone interested... /forums/images/graemlins/smile.gif
Just a follow up report...
What I reported in the above post is not happening on my normal computer. The above post was made from a laptop in my workshop. The laptop is running XP like this computer is, and I think (but don't remember) it has SP2 installed...
I think the reason had something to do with privacy level setting related to cookies...
I lowered the privacy level (I think I might have been messing around and raised it recently on the computer in question), and while it did not seem to make a difference right away...
The next time I powered up that laptop everything was back to normal.
Guess I should increase the privacy level again just to see it that is the real cause...but I probably won't go to the trouble since things are working fine now.
   / All threads marked read in each forum! #4
its always been like that for me i know nothing else - what is you privacy level set to henro?
mines on medium at the moment
thanks
It's at the medium setting on my normal computer and I think after returning it to the medium setting on the other computer things went back to normal...
What I mean is that things went back to normal, and that happened after I changed the privacy setting back, so I ASSUME that was the reason things went to normal. I do think I had to reboot the computer before things corrected themselves though...at this point I am not really sure...
   / All threads marked read in each forum! #6
my comps always been on medium so maybe its just messed up, ah well thanks for the help
   / All threads marked read in each forum! #7
Henro, I know this is an older thread, but I rarely come into this forum. The same thing has happened to me pretty much all along, and I really hate it. I sometimes get interrupted and have to back out of a forum and when I come back, the newer threads are marked as read, and I miss a lot of them.
Sometimes, this seems to happen to a lot of posts when I've never even gone into that forum for a few days, and the new posts are not marked as unread, so I miss those too. Then I sometimes end up coming into a post at the wrong point and don't realize it, and post something not pertinent to the ORIGINAL thread, which can be embarrasing at times.
Oh well, I'm just venting I suppose, but I wish I could figure out why this happens. Security setting is at medium, where I prefer to keep it. John
   / All threads marked read in each forum! #8
I never use the index to jump around, I use the thread jump. But I still see some threads that I've read marked as if I had not read it. Opposite problem that you've seen.
It does not do this all the time. I also visit both from work and from home.
But, other forums that I frequent do not even try to show what you've read. You have to go thru the whole thread a 2nd or 3rd time to get to where the new posts are. Most of them run vBulletin. No idea what software they use to run TBN but it seems a step above other forums I've visited.
Moon of Ohio
   / All threads marked read in each forum! #9
This has been a pet peeve of mine for as long as I have been here. I have asked why this happens before but never got a satisfactory answer. Since I have changed jobs I don't have much time to check this site. When I do, I read a few new topics & think I will come back later & read the ones I didn't get to & they all are marked as read.
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
2018 CASE IH 110N LOT NUMBER 223 (A53084)
2018 CASE IH 110N...
378764 (A51573)
378764 (A51573)
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A52577)
2016 PETERBILT 579...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2022 TAKEUCHI TL12R2 SKID STEER (A51246)
2022 TAKEUCHI...
