Allis Chalmers One-Sixty 3 pt won't lift
   / Allis Chalmers One-Sixty 3 pt won't lift #1
AaronS
Platinum Member
Santa Claus, Indiana
LS XR4046HC, New Holland Boomer 1020
Hi all. We have an old One-Sixty that came with the purchase of our small farm. I learned this morning that it was built in France around the same time I was born and online reviews seem overall good. Built by Renault and has a 3 cyl Perkins. Great running little tractor, but last night when attempting to carry a round bale out to the horses the 3 pt wouldn't lift. Wouldn't budge at all. We thought we'd check the hydraulic fluid level thinking that maybe it is low, but felt less than intelligent when we couldn't even find a fill hole for hyd. I saw on tractordata.com that the engine takes 29 quarts of oil (seems like a misprint). Surely the engine and hydraulics don't use the same oil? Does anyone know? Before last night the 3 pt worked as it should.
   / Allis Chalmers One-Sixty 3 pt won't lift #2
Tractordata lists the engine oil capacity separately @ 6.5 quarts.
That makes a lot more sense! Thanks DT.
   / Allis Chalmers One-Sixty 3 pt won't lift #4
Wish I could have actually helped though.
Check the top of transmission case / rear end for what looks just like a drain plug, ie takes a ratchet wrench to open.
I found a downloadable shop manual on classicmachinery.net. That should help!
   / Allis Chalmers One-Sixty 3 pt won't lift #6
I am not sure if the 160 has the "position" control like my 170 Allis had, but if that is set at the wrong position your 3 point arms won't lift. Do you have another 1 or 2 levers with numbers 0-9 right behind your 3 point lift lever? If you have the traction booster lever and position control lever set wrong it will interfere with the 3 point lifting properly. I am not 100% sure on this but it is worth looking at. Good luck and let us know what you find out.
Thanks pizzaguy. Our One-Sixty has two levers side by side. One is the 3 pt lift and the other has the number 0-9 with it. I tried to lift with the other lever at various locations/numbers, but I'll try it again in more depth.
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 20ft...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
2019 ALLMAND LIGHT TOWER (A58216)
2019 ALLMAND LIGHT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
2013 PRIME TIME RV LACROSSE (A58214)
2013 PRIME TIME RV...
Giyi 72" Grapple Bucket (A57149)
Giyi 72" Grapple...
