Almost impossible to pull starter cord
   / Almost impossible to pull starter cord
KennyG: No, we did not do anything to the piston or cylinder since they were in excellent shape. The pull was difficult even before we got started on the "redo", basically no change. Like I mentioned before, with the plug removed, it pulls with ease. I see reasonable spark, Have tried starting fluid both in the cylinder as well as thru the carb. Also a small bolus of gasoline into the cylinder, but still no success. I even tried the cordless drill with a make shift rubber clutch against the housing of the recoil/flywheel, but it can not overcome the resistance that the cord pull can deliver.
   / Almost impossible to pull starter cord #12
I am not sure about Tecumseh but most of the larger single cilinder engines have an automatic compression release. It is usually on the camshaft and opens the exhaust valve early to release some of the compression so you can crank it.
Bill
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
2014 International Derrick Digger Truck (A55973)
2014 International...
2022 Vermeer 573 (A55973)
2022 Vermeer 573...
2024 Frontier FL1061S Hydraulic Flail Mower (A56438)
2024 Frontier...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59904)
2019 INTERNATIONAL...
2021 NEW HOLLAND GS72 HD FRONT MOUNTED BRUSH CUTTER (A57024)
2021 NEW HOLLAND...
