Alternate source for hydraulic top links?
   / Alternate source for hydraulic top links? #21
Now I have to try it out on my gravel lane and get the left side link adjusted to a happy medium for the way I use it. I tried to make the the overall length of the 6" sidelink cylinder so that I'd have more tilt right than left (welded the clevis at 4" stroke instead of halfway at 3"). I have plenty of tilt, the only question left is will I need to add a DPOCV on the side link too, but I'd rather not.
quote]
Glad to see that this has worked out for you. :thumbsup:
Maybe it is just late in the day for me, but what do you mean when you say that you have welded the clevis at 4" instead of 3", and why do you want more tilt one way vs the other? :confused3:
Hi MVR, this will probably be harder to explain than it was to do, but I'll try it: First thing to make clear is the adjustable OEM side link (which I moved from the right side over to the left) only has 4" of total travel available. I built this HSL from a 6" stroke cylinder, so I had an extra inch of travel each direction from the mid point to play with.
Initially, I was going to just screw the OEM SL out to the midpoint of it's adjustment range, measure it, and make the HSL to match that overall length when the 6" cylinder's rod was extended to its 1/2 stroke position. That would have matched the original side link's overall length, and would have left me with about +3" and -3" adjustment available on the right side of the tractor, compared to the +2" and -2" of the OEM SL on the left side. When they were both set at their mid points, the implement would be level. Simple and straight forward.
However, I decided I might want a little more tilt to the right than the left, so instead of extending the cylinder rod 1/2 of it's travel (or 3"), I extended it only 2". Then I just cut off the rod the right amount to equal the desired overall length including the length of the clevis that I removed from the fixed side link. That matched the overall length of the OEM SL, but meant the cylinder was extended 2" instead of 3" when it matched the OEM SL's overall length. Therefore, the HSL's available adjustment range (compared to the OEM SL) became +4" and -2" instead of the originally planned +3" and -3".
As for why, I'm right handed and old and stiff in the back, so I do most of my twisting around and looking back while box blading over my right shoulder, not my left, and all the important controls are under my right hand, including the TnT control levers. So I set this up so I could dig a little deeper to the right if I want to. Not a very dramatic reason, but it made sense to me.
BTW, if anybody else is considering doing this, it was a lot easier to do than I thought it would be at first. In fact, the hardest part has been getting all four hoses routed so they don't get pinched, stretched, or bent too much when the box blade is waving around back there at all kinds of odd heights and angles.
SAFETY WARNING: Haven't seen this mentioned before, but Top and Tilt moves a three point hitch around A LOT when you start playing with the side link, and I can personally attest it is capable of whipping a 400+ lb box blade around so fast you won't believe it if you don't go easy with it. Make sure nobody is anywhere near the implement when manipulating the controls, including you!. In fact, I may consider adding a needle valve or restrictor to slow mine down some, so I don't have to be so careful about feathering the levers.
   / Alternate source for hydraulic top links? #23
Picker77, thanks for your reply, glad that it worked good, hope it works out well for you. ;)
   / Alternate source for hydraulic top links? #24
One question about banjo fittings... can they be removed and reused (as in swapping the hoses above) without changing to new copper rings, or is that a no-no?
If you flip the washers over you should have no problem. TnT looks fabulous:thumbsup:
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
Tandem Axle Rear Trailer Frame (A55852)
Tandem Axle Rear...
Plasmarc PM150 Plasma Cutter (A55851)
Plasmarc PM150...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
Genie GS-1930 19ft Electric Scissor Lift (A55851)
Genie GS-1930 19ft...
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
