alternator check
   / alternator check
now the alternator seized. hope a new one isn't expensive.
   / alternator check #12
Sounds like you've just found your problem.
   / alternator check #14
I would not buy a new one. Take it to a local rebuilder.
   / alternator check
new ones are pricey....$370. I took the alternator apart and found that the ball bearing is shot. i took that off and then put the alternator back together and mounted it back on the tractor without the bearing. seems like i could use the tractor now. not sure how long without the bearing.
i'll look around for a place to get the alternator rebuilt on tuesday after the holiday weekend.
   / alternator check #16
If you run it without a bearing, you won't be getting it rebuilt. You'll be buying a new one!
ron
   / alternator check #17
Sounds like it's leg pulling time.
   / alternator check
how would pulling my leg fix my alternator?
   / alternator check #19
Got a picture of this? :D
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A51692)
2003 Pierce Tilt...
2019 CATERPILLAR 299D2 XHP SKID STEER (A52705)
2019 CATERPILLAR...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
