Raspy
Veteran Member
- Joined
- Dec 16, 2006
- Messages
- 1,656
- Location
- Smith Valley, Nevada
- Tractor
- NH TC29DA, F250 Tremor, Jeep Rubicon
Diesels engines are always inherently lean burning. That is, unless they are under full load and then you see some smoke. Brown is fine, but black means excess fuel that is not getting burned completely. This is the best indicator of the engine being at full power for a given RPM. Remember, they always take in a full charge of air, then the fuel is added to start combustion. At higher altitudes, they get less air, so they might smoke more at full load and lose about 3% of their power or so for every 1000' elevation. The mixture is constantly changing and can't be discussed in the same way as a gasser. There is no such thing as lean or rich adjustments on a diesel, that is what the throttle does. It's more about how aggressive the fueling ramps up and the maximum fuel delivered. Smoking does not necessarily mean rich.
White smoke at startup means cold cylinder walls and moisture with incomplete combustion. Brown smoke means good combustion and about 75% output. Black smoke means full power and either excessive fuel or poor atomization. It can also mean a bad injector if the engine is not putting out much power and smoking.
Turbocharged diesels with mechanical injection often have barometric compensators that ramp up the fuel based on intake manifold pressure. These should not smoke so much and should produce about the same power at altitude.
High pressure common rail injection diesels with turbo chargers measure the intake air temperature and the manifold pressure to select the right amount of injection and should smoke even less while producing good power. The computer gathers information and refers to a chart, or fuel map, to decide how long to leave the injectors energized for a given RPM and throttle position.
