Aluminum vs Steel Trailers
   / Aluminum vs Steel Trailers #11
i suppose your right that aluminum can be welded with mig, i just never saw any mig welded aluminum in structural heavy duty applications,steel as you say, yes but aluminum takes alot more heat to do, and also you wont be mig welding heavy aluminum and getting good penetration with a small cheap mig, it ususaly takes a 2000 dollar mig and spool gun from what i have seen, but i realy have only used tig for aluminum myself
   / Aluminum vs Steel Trailers #12
Aluminum Welding:
Yes, it generally takes a spool gun to feed the wire reliably, but it can be done with a short enough standard MIG setup with the harder Aluminum wires. Besides the equipment, the gas (Argon) can be a bit more expensive as well.
WARNING - Why Not to Weld Aluminum Even if You Can!
If you are randomly welding things onto structural Aluminum frame members of your trailer, you will destroy the heat-treated strength properties of the alloy in that area, turning it from your nice strong 6061-T6 or 6063-T6 into O temper. If it turns out to be a critical section of the structural part, it could later fail. The only way to make the welds in Aluminum as strong as the original heat-treated alloy is to re-heat-treat the assemby after its welded. Generally impractical for something as large as a trailer unless you are an aircraft manufacturer and have some really big ovens.
Even though holes also weaken and concentrate stress, I think you are better off carefully drilling holes (with a sharp bit and lots of coolant/lubricant so as not to heat the part) and bolting or riviting the extra stuff on.
Stress Cracks:
Are always due to poor design or overloading beyond the intended design. A proper design would limit the repetitive stress and vibration in a given member to stay well below the repetitive stress threshold of the material in question. This is a well-understood property of the aluminum in aircraft design, for example. Some trailer manufacturers may not pay any attention to this. They go by a rule of thumb or use the ultimate strength instead of the repetitive strength. They test it with the rated weight once, and call it good. Their products may fail due to stress cracking. Especially vulnerable are welded connections between frame members. A: Stress tends to concentrate there due to the geometries involved, and B: The metal is the weakest there due to the temper being lost due to the welding.
Why to use Aluminum for a trailer:
1. Lower Trailer Weight = Higher Payload for a given towing vehicle max total towed weight. My '91 Dodge Dakota, for example is only rated to tow 5000 lbs. If I were to try and use a 3800 lb tilt-bed steel equipment trailer, I would be limited to a 1200 lb tractor to haul around. If I instead use a 1000-lb, non-tilting, Aluminum trailer, I can put 4000 lbs of tractor and attachments on it.
2. Safety - the lighter the trailer/load combination, the easier it is to control the vehicle and trailer.
3. Fuel economy - but as one poster pointed out, this only turns out to be a win if you put on enough miles hauling the trailer to make up for the higher cost of the Aluminum.
4. Cosmetics - the aluminum will age more gracefully. Yes, the steel may remain structurally sound, but is is going to look bad after 20 years unless you re-paint it. The Aluminum will dull with age, but will generally not be painted, so there will be no paint blistering and peeling off.
5. Ease of storage / moving by hand. If you ever have to move a trailer by hand to put it away in your stoprage area, you will appreciate the aluminum.
Why not to use Aluminum for a trailer:
1. Money is always an object.
2. Familiarity.
Design and fabrication requires different knowledge, skills, and tools than the more-common steel fabrication. Those not familiar with building with aluminum are likely to produce a sub-standard product if they don't take into account its differing properties and design and fabricate accordingly.
3. Sometimes more weight is an advantage. For example, if a dump-trailer was made super-light, it might tip over easier if raised on a slight side-slope.
   / Aluminum vs Steel Trailers #13
L.B.,
As others have stated, it depends. In my opinion, for horse trailers, Aluminum is the way to go.
I suspect that in other applications Steel might be a better choice. Perhaps with more detail regarding your use or needs a better answer can be provided.
Mark
   / Aluminum vs Steel Trailers #14
I have a 22' trailer with a 2' beaver tail made with 4" X 6" steel angle. The bed is treated 2 X 10's. It is rather strong being that I ran the 4" X 6" angle across every 16" the entire length, and it sits on 2 6000 pound axles. However, the thing weighs over 4500 pounds empty. I've had people want to borrow my trailer only to find out that my trailer alone is over their towing capabilities. /forums/images/graemlins/blush.gif
I want aluminum but can afford steel. /forums/images/graemlins/mad.gif
   / Aluminum vs Steel Trailers #15
</font><font color="blue" class="small">( Aluminum vs Steel Trailers
Which is best?
)</font>
ALUMINUM
RedDog
   / Aluminum vs Steel Trailers #16
I have very happy with my aluminum trailer. It is a 6.5'x12' Worthington. The main advantage for me is the weight. I can put the trailer into my storage barn by hand (the door is low, so I have to raise the trailer up for the ramp to clear.) This trailer also weighs about 500lbs., giving me a legal load capacity of 2500lbs. It still looks close to new after five years of use.
The price is an issue, to be sure. I paid $1800 for mine five years ago, and that was with an awesome discount from a friend who was the dealer (sadly, he passed away 4 years ago.) I would like an 18 or 20' tandem now that I have a bigger truck, but I am too scared to get a price /forums/images/graemlins/shocked.gif
Will
BESTWAY AG VSK50 LOT NUMBER 80 (A53084)
BESTWAY AG VSK50...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2022 Ford F-250 XL...
2006 PETERBILT 379 MID-ROOF SLEEPER (A52472)
2006 PETERBILT 379...
1262 (A50490)
1262 (A50490)
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2008 JLG 450AJ SERIES II MANLIFT (A51246)
2008 JLG 450AJ...
