patrick_g
Elite Member
Ah, yes, a variation on the Woody Allen comment about ************ causing blindness. He quipped, "How about if I quit when I'm nearsighted?"
Pat
Pat
SPYDERLK said:I appreciate that. Seriously tho, suppose the 10th dentist said; "If its important to you to eat candy a lot you should rinse your mouth afterward and brush your teeth more often in order to keep the sugar from feeding tooth rot. Thatwill keep your teeth ok, but Id also recommend that you monitor pancreas function, blood sugar, and insulin resistance for indications that you may have to modify your habit." ?
larry
Spiveyman said:I don't really know much about the function of the HST tractors. I only have experience with old gear tractors, so I really don't know what things could mess up in there, but it sure seems wiser to work in a lower gear.
SPYDERLK said:jb, The HST relief prevents shock load to the internal parts. You just see something akin to punching the pedal to the floor when the engine is reved up. The tires either spin or the relief pops. Maybe both. Likewise with hitting a stop or popping the clutch on gear -the tires spin or the clutch slips. Too much traction or clutch, with a low pullpoint to prevent it moving to rear up and somethings gotta give. Tires can wind up a little, but the HST relief wins out hands down in protecting the internal system. Doesnt protect the load points on the frame tho when you hammer an obstacle as you say.
larry
SkunkWerX said:...snip...
Let us know how it goes?
Good LUCK!
barneyZ said:The longer I worked at it, the more finesse I discovered and less brute force I needed.
Barney
I did that 2 years ago for the front yard sprinklers. I learned that trenchers don't like rocks, and I've got lots of rocks. I also spent $12k on a tractor so renting equipment depresses me. I'd rather take that c-note and put it towards a new attachment. Now, I just have to decide on a field mower, snow plow, tiller, rock rake...ToadHill said:Rather than damage the Tractor, I'd take a trip to the rental stor and rent a trencher for about $100 a day. You can easily do 500' in a day.
