amber light and rear light on
   / amber light and rear light on #11
beanbag said:
Took a picture of the symbol and the writing and showed it to a Korean Guy at work he said that the light is for WATER LEVEL so must be a bad sensor thanks for all the in put.
I have never seen a YM1500D with a warning light for "water level". The amber light on ours is for coolant temperature, and running in an overheating situation, even briefly, is a primary cause of head gasket failure which can lead to major engine damage. Strongly suggest you get those manuals that are available and spend time reading them and threads here before you further use your new purchase. I say this respectfully, but it is apparent you need to spend some time educating yourself to protect your investment. It does not use gas, nor have a gas pump, nor have any form of fuel sensor.
You might also want to confirm the model number if you haven't already. A decal is proof of nothing, and there are plenty of places that have been known to rebadge used tractors.
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2017 Volkswagen Golf Hatchback (A51694)
2017 Volkswagen...
2002 Almac 4,200 Gallon Fuel Tank Truck Body (A51692)
2002 Almac 4,200...
1 pallet of Brake Chambers (A53117)
1 pallet of Brake...
2015 JLG 449 12ft Drop Deck Equipment Trailer (A51694)
2015 JLG 449 12ft...
