Amp-Probe question
   / Amp-Probe question #11
John47 said:
Amp-Probes aren't designed to measure DC current, they are an AC instrument that operate off the "transformer" principle. (Mutual Inductance) What you need is an "in line" DC ammeter of some sort, like a multi meter with 10 or 20 amp ranges.
I used to use my expensive VOMs as inline amp testers.. but tired of taking them aprt and replacing hard to get to fuses when i fould a circuit that pulled 11 amps.. etc..
So i hit the local auto store and bought a cheapy sunpro ampmeter.. 9$.. I added wires with gator clips to it. It is now a great inline ammeter.. polarity indicative due to meter swing.. and good for 60a.. etc.
Soundguy
Soundguy
I haden't even thought of an automotive amp meter and there just may be one around here lurking in the pole barn. Thanks for the tip SoundGuy!
   / Amp-Probe question #13
That is excellent advice Chris, I think I will steal that idea in the future as well:)
That's the real beauty of this site KennyD. Members teaching other members....... :)
   / Amp-Probe question #15
Don't remember what resistor I used but I once built a 50 amp dc meter out of a not to expensive Radio Schlock amp meter, a resistor and some alligator clips.
Farwell
   / Amp-Probe question #16
Considering an ammeter is on;t a 'shunt voltmenter' It's easy to measure a voltage drop from a known load, if you also know system voltage, then make a comparison, and calculate amps.. etc..
soundguy
   / Amp-Probe question #17
Get a few fuses and put them in line. When they stop blowing, you found yoru value!
Mike
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2007 Allmand Night-Lite Pro Towable Light Tower (A51691)
2007 Allmand...
FORD 555B BACKHOE (A51246)
FORD 555B BACKHOE...
2007 Utility 3000R 53ft T/A Reefer Trailer (A51692)
2007 Utility 3000R...
Toyota 42-4FG25 4,000 LB Warehouse Forklift (A51691)
Toyota 42-4FG25...
