amsoil for JD transmission
   / amsoil for JD transmission #1
heehaw
russellville, arkansas
Kubota M4900, B7510 and RTV
JD has "wet" brakes; and according to all the JD shops i have talked to, if you don't use their hyd fluid/oil in the transmission, the break pads will come apart?? i've had this happen to one tractor, i'm not saying it was because of the wrong hyd fluid; but its quite expensive, since that also stops up the screen and filters in the hyd system; i'm considering changing to the amsoil equal of JD's hyd fluid, but don't have a clue which one that is..anyone have an amsoil number??
heehaw
   / amsoil for JD transmission #2
Heehaw, I put (ISO 46, SAE 30) ATH-05 (5 gal pail) the ATH 30 is (30 gal drum) & ATH-55 is (55 gal drum) they do not package it in qts. for JD 2 5 gal pails will be more than enough. It will not damage the wet brake linings in any way. Any more questions be sure to ask. Good Luck gary
   / amsoil for JD transmission #3
Amsoil passes the John Deere specification (J20C, J20D, J14C). Also drops brake chatter by approx 50%. It should drop temps a bit also. Hence, it is okay to use! Works better for me in the winters! If you need any at a dealer price just ask. That goes for anyone. Hay, I like the stuff a lot and the best thing I like is there oil. It does not turn black right after you install it in the motor! Over ten hours on oil & it is still 98% clean.
"Were going to need a bigger boat" JAWS
Got the tractor, need bigger yard to play in!<P ID="edit"><FONT SIZE=-1>Edited by burnickas on 01/15/01 06:10 AM (server time).</FONT></P>
   / amsoil for JD transmission #4
Burnickas, how do I get the ATH oil at dealer cost? I will be changing my trans fluid soon to Amsoil and the cost is a little disturbing. I live in NJ. Thanks, Rich.
   / amsoil for JD transmission #5
Rich,
I became a dealer so I could get the stuff cheaper. I also help other people/friends get the same dealer price. Yes the price is some what high. If you want the Amsoil Synthetic Tractor Hydraulic/Transmission Fluid, ISO 46, SAE 30 - (1) quart bottle retail is $5.05 or (1) case is retail $59.40. Again, these are retail prices. Dealer price is lower but I don’t want to post them since it could get some members angry. You could email me for the dealer price, call me for dealer price or you could call Amsoil and use my dealer number, your credit card and give them your shipping address and you will have the oil in about 3 to 5 days! The case is the best deal
   / amsoil for JD transmission #6
Burnickas, Where can you get the ISO 46 (sae 30) in the qts, My catalogue nor Amsoil in Superior says it is available. only 5 gal pails, 30 gal drums and 55 gal drums. Thanks gary
   / amsoil for JD transmission #7
Garya- If you are looking for Synthetic Tractor Hydraulic/Transmission Fluid, ISO 46, SAE 30 - (1) quart bottle
retail is $5.05 and the item number is ATH-QT.
** ATH-QT meets or exceeds John Deere JDQ-42 PTO Clutch (2000) Cycles - Pass, John Deere JDQ-40 Brake Capacity Test - Pass, John Deere JDQ-40 Brake Torque Variation (Chatter) - Pass, John Deere JDQ-73 Cold Soak @ -35°C - Pass, John Deere JDQ-74 Slow Cool @ -30°C - Pass, John Deere JDQ-74 Slow Cool @ -35°C - Pass
If you are looking for regular Synthetic Anti-Wear Hydraulic Oil (ISO 46), yes it only comes in 5-gallon bucket and 55-drum. Product number is AWI-05 or AWI-55.
Any other questions just post or email
Got the tractor, need bigger yard to play in!<P ID="edit"><FONT SIZE=-1>Edited by burnickas on 01/16/01 04:36 PM (server time).</FONT></P>
   / amsoil for JD transmission #8
Burnickas, Just got my new Action News today and on the second to the last page says that it is indeed available in qts now. I hope they also change their catalog. Thanks for the info. gary
   / amsoil for JD transmission #9
GaryA --No problem about the help. If you ever have anyother problems/questions just ask me. They came out with the Tractor Hydraulic/Transmission Fluid in quarts back in Sept/Oct but they waited to "go public" with the New Year (don't ask). They only way you could order it was over the phone.
RJA -If you think dealers get good prices you should see what the commerical people get! Anyone could start a commerical account all you need is a tax number and the only draw back is that you have to buy all products in cases or larger. **I am not promoting this because you will have a garage full of product. :)
Got the tractor, need bigger yard to play in!<P ID="edit"><FONT SIZE=-1>Edited by burnickas on 01/16/01 04:37 PM (server time).</FONT></P>
WOW; i looked up the price of the amsoil hydraulic fluid/oil last night...since the tractor takes @8 gallons, i may have to wait a while; i thought JD was high on their fluid..
heehaw
UNUSED FUTURE SKID STEER PALLET FORKS (A51244)
UNUSED FUTURE SKID...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
2018 CATERPILLAR 303E CR EXCAVATOR (A51242)
2018 CATERPILLAR...
2020 CATERPILLAR 326FL EXCAVATOR (A51242)
2020 CATERPILLAR...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
