annoying bouncy ride pulling trailer
   / annoying bouncy ride pulling trailer #31
Misfire said:
Didn't you notice I was agreeing with you? I had them balance my trailer tires.
I am sorry, guess I read something else into it. You are a smart man for insisting on balancing.
Chris
   / annoying bouncy ride pulling trailer #32
Not balancing trailer tires, maybe why so many trailer tires fail.
Dave
   / annoying bouncy ride pulling trailer #33
Still have them balanced. Its the only wat to find out if you have a bent rim.
Spin balanced.
Chris
Bud already explained that the vibration was at a slow speed, below that affected by balance.
Trying to balance a bent wheel is a waste of time. It won't get you a thing.
If you think a wheel might be bent just jack it up and spin that wheel by hand. You can see if it's bent enough to cause a problem or if it spins true. Very easy and avoids a trip to the tire shop for an unnecessary procedure.
Balancing the wheels is good thing to do, but it won't fix a bent wheel or a flat spot.
   / annoying bouncy ride pulling trailer #34
Yea, but putting it on a balancer will tell you a lot about things. Its fairly cheep. My tire guy does a spin balance and rotation for $15.
Chris
Well I lowered the ball 4 1/2" and it made a huge difference at all speeds. Pulled the trailer about 150 miles today and up to 70MPH and it pulled real smooth. At times you couldn't even feel it behind the truck. Apparently this problem was a "trailer level problem". Thanks again for all the advice!
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58216)
2014 AMERITRAIL...
2005 INTERNATIONAL 9400I MID-ROOF SLEEPER (A58214)
2005 INTERNATIONAL...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
Hydraulic Breaker Excavator Attachment (A55973)
Hydraulic Breaker...
JOHNSON 5 1/2HP SEAHORSE OUTBOARD MOTOR (A58374)
JOHNSON 5 1/2HP...
