BravoXray
Elite Member
- Joined
- Dec 17, 2019
- Messages
- 2,711
- Location
- Nothern Indiana
- Tractor
- Kubota BX2230, John Deere 430 Diesel
Today was warm but VERY windy, so I decided to do the annual end of mowing season service on my BX. Drained the oil, changed the oil filter, air filter and the fuel filter on the engine. After the oil had drained, I installed a quick drain valve, which should eliminate a lot of the oil mess when the drain plug is removed. It screwed right in and I snugged it up, should work just fine. My only concern though is that it doesn't have a very good flow as the bore is rather small, but as long as the oil is pretty warm, it should be okay.
I also checked the hydraulic/HST oil, coolant, mower gearbox oil, front axle oil. and greased the mower deck, PTO shaft u-joints, gauge wheels and FEL. I wish the front drive shaft had zerks on the u-joints, but it doesn't.
Here is a picture of the quick drain valve installed.
