Another 2020 hydraulic oil leak
   / Another 2020 hydraulic oil leak
I replaced the brakes many years ago when the first hyd pump went out. I don't put many hours on this tractor per year, maybe 100 at most so I'm confident that the brakes are still good. I never did do much about the metal in the hyd fluid other than change the oil and the filter a lot and keep magnets in the filter and make sure the screens in the pump are clean. I could attempt to take off the rockshaft housing and flush out what I can find somehow but I doubt if I will ever get it all. When I drain the hyd oil it looks clean but there's always a bit of metallic sheen on it. Like I said when I had the RS PS housing off, I could see a build up of fine metal filings on a surface under the PS main shaft though.
So you're saying the seal and maybe the bushing on the load control shaft can be replaced externally? Yes I was reading from the Tech Manual TM-1044 under section 30 "Load Control Mechanism". It says to remove the rockshaft assembly and left hand rear axle housing to service that. But it looks like it's just a bushing and O-ring? Maybe I could get buy with just the O-ring? All the other o-rings/seals in this tractor were dry and brittle.
I wouldn't mind trying to flush out some of the metal if it's not a weeks project full time. I'm sure it's not doing any good but that's the way I got this tractor in about '85, unknown to me. Between the brakes, hydraulic pump and clutch I've got about as much into it as I paid for it. The engine has always run good but the loader control valve leaks and so does the 3 pt. hitch, but they work good other than that.
I use it to mow the 20 acres with the NH 7' sickle bar and snow removal in the winter. But I don't know how much longer we can keep this up, wife's 75 and I'm 73.
   / Another 2020 hydraulic oil leak #12
I've changed the load shaft o-ring and bushing on a 2030 without draining oil or removing the load shaft. Slide the shaft in just far enough to access the bushing and o-ring. It will leak oil as you do this, but not a lot. Have everything ready and do it quickly.
Is the bushing a press fit? I'd be more than willing to drain the oil not to have it go all over the place. It's not a big project. As I remember there's a drain plug right below that area.
The bushing and seal seem to be available, but not the o-ring AA730R?
If I take off the rockshaft housing I might as well replace the o-rings and seals in the piston and lift arms. There's a piston repair kit I see. That doesn't look like an impossible job for me. It's a lot of parts to keep track of.
   / Another 2020 hydraulic oil leak #15
DogT: Double-check your availability - The O-Ring is #A4730R.
I, too, have replaced these seals and O-rings once. Like "Zebrafive" did - I slid the shaft sideways, R&R the seal & O-ring. Slide it the other way... etc. Collected maybe 500ml (1 Pint) oil in a pan, total.
If you want to flush the trans this is a good time to do it, of course.
Thanks for correcting that. So just the seals and ring, not the bushing. It's worth a try for a few bucks. The trans oil has been changed last fall. Good to know I don't need to remove the wheel/axle.
   / Another 2020 hydraulic oil leak #17
Bushing depends on wear. You can check for movement first with just the draught arms removed. Wheel spacing will determine the amount of room you have. I found the tyre was convenient to lean against.
UNUSED WOLVERINE QUICK ATTACH MOUNTING PLATE (A51248)
UNUSED WOLVERINE...
2004 Kia Optima Sedan (A51694)
2004 Kia Optima...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
BOBCAT T595 LOT IDENTIFIER 140 (A53084)
BOBCAT T595 LOT...
UNUSED FUTURE 32" HYD TILTING BUCKET (A51248)
UNUSED FUTURE 32"...
