Another 8N ignirion question
   / Another 8N ignirion question
Soundguy said:
i'd look at somthing other than gap for the rough idle
choke help any?
any leakage on the secondary wires.. view at night?
spark plugs look good?
any cyl makemore of a difference or no difference, than the others if you unplug one at a time?
The plugs are new and i checked them for cracks in porcelain or other damage. I shut the barn lights off to see if there was any arching. I found none. I had to come in and wasnt able to go further. The rough idle did not occur before the rewire and tune up. It sounds like it has a hot cam in it and clears up around 1/2 throttle. I verified all plug wires are in the right location also. Yesterday i removed the air intake and verified the choke was opening and closing as it should. I will be in the barn all day tomorrow reassembling a 283 for a friend and will dig some more. Thanks for the help and patience as i figure things out.
   / Another 8N ignirion question #22
have you adjusted the idle air needle?
Found it this morning. The #2 plug had a very weak spark compared to the other 3. I swapped plugs and no difference. I swapped out the plug wire and idle smoothed out. In my past experience, i had plug wires break down at higher rpm, not idle. When i checked plugs and wires yesterday, the rough idle always worsened when removing wires. Replaced the wire and so far so good. I will update on any changes. Thinking about painting it this fall. Will definitely have questions about that. The last paint job was rattle can, would like to do a more permanent job this time.
   / Another 8N ignirion question #24
glad you found it.
just have to work thru it 1 piece at a time.
painting and prep are easy.. time consuming.. but easy.
I spend more time prepping for paint than fixing a machine up to get it ready to be painted. and then painting itself, if weather is good, can be 1-2 days depending upon machine..
look forward to hearing back from you.
Soundguy said:
glad you found it.
I am thinking of using a rust oleum type product or something with good durability. The tractor is used a few times a year, mainly for dragging the horse arena and covering rye grass seed. I am looking for a durable paint but not too expensive. Iirc, napa has a few good choices that are relatively inexpensive.
   / Another 8N ignirion question #26
origina;;y I'd have said valspar.. but since tsc stopped carrying it.. hard to find.
nason at carquest is next cheapest usually.. takes different reducer though
2015 Dodge Charger Sedan (A50324)
2015 Dodge Charger...
3 pt Ditcher Plow (A50515)
3 pt Ditcher Plow...
CATERPILLAR 308CR EXCAVATOR (A51242)
CATERPILLAR 308CR...
UNUSED FUTURE MINI EXCAVATOR GRAPPLE (A51244)
UNUSED FUTURE MINI...
2012 TOYOTA (A50324)
King Ag Cattle Feeder (A50515)
King Ag Cattle...
